Question about Garmin Cell Phones
My garmin phone will not open .message on screen the application garmin process com garmin android .garmin has stopped unexpectdely. please try again. trying but no result after much trying.
Posted by Geoffrey McFarlane on
5 Related Answers
SOURCE: how do i get rid of error message "the application
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
Posted on Oct 26, 2010
Anonymous
  • 157 Answers
SOURCE: The process com.android phone has
I would start with a Master Reset. That's the best place to start.
Pulling the battery doesn't really do anything but fix little problems.
Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state. Press HOME > MENU, then tap Settings > Security > Factory data reset. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons, with the phone turned off, press and hold the HOME, END CALL/POWER, and BACK buttons. The reset process will start after a few seconds
Posted on Mar 29, 2011
Anonymous
  • 7 Answers
SOURCE: Application Calender Storage( process com.android.providers.calender)has
When a message like this pops up there is usually a "Force Close" button located one the pop-up, click it. This shouldn't even be happening, this is a built-in application for storing calendar events, if you don't mind not being able to use the android calendar that's fine, but if you want to use it and want to keep your warranty, take it back to your carrier's store, ask them to either swap your phone or somehow reinstall the OS so that everything works. You didn't do anything.
Posted on May 13, 2011
Anonymous
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
Posted on Nov 04, 2011
Anonymous
SOURCE: WonderMedia WM8650 Android 2.2 7"
1. Go to Settings
2. Go to Applications
3. Go to Manage applications
4. Go to all tabs
5. Gp to "Market" applications
6. "Clear Cache" then "force stop" - DO NOT CLEAR DATA
7. Now go to "google service framework" applications
8. "Clear data" then "force stop"
9/ Reboot your machine/
This should solve your problem
Posted on Dec 14, 2011
Whenever I turn my Android Huawei on the home screen never shows up, instead theres a black screen with a weird message
factory reset ur phone once... an see if it is fixed or reflash the os that can be done free of charge at the service center
Emails wont open on my galaxy s screen turns black and says foreclose
seems you installed a non conpatible version of the email client. did you download an apk from an extener source and install? I will suggest you uninstall it and reinstall the yahoomail from market.
Onda android vx610a manual
I dont know how to do it fixet : the application lancher (process com.android.lancher) has stopped unexpectedly please try again
Hello, my lg optimus swift is not working correctly. when i turn on the phone, sometimes it displays this sorry! the application Android Phone (process com.android.phone) has stopped...
my lg optimus swift is not working correctly. when i turn on the phone, sometimes it displays this sorry! the application Android Phone (process com.android.phone) has stopped unexpectedly. And it not receiving or sending any calls with the signal only dropping.
3helpful
How do i get rid of error message "the application Open House (process android.process.acore) has stopped unexpectedly. Please try again."
Thanks and regards,
Anil.B.R
Cell Phones Logo
Top Garmin Cell Phones Experts
Mandeep  Singh
Mandeep Singh
Tom Chichester
Fred
Fred
Are you a Garmin Cell Phone Expert? Answer questions, earn points and help others
