Question about The Kitchen Appliances - Others
I want to know the expiration date of a bottle of Marukan Rice vinegar. The label shows a best used by date of 051316A What does that translate into real time date?
Posted by Calvin Chun on
Pcm2048
  • 754 Answers
Anything with a best by date does not have an expiry date. The best by date means that the product will still be fresh by that date and afterwards may not be as fresh. Products like cheese and milk have an expiry date as they should not be used after that date. Products with a best by date can still be used after that date but may not be as fresh. With something like vinegar, you can use it a long time after the best by date.
Posted on Dec 09, 2017
blevinslance
    New Friend:
  • 55 Answers
Month day year may 13th 2016 idk what the a is for
3 Related Answers
DJRydr
  • 5 Answers
SOURCE: Don't know how to set time and date on
I believe that this is the manual that you are looking for, http://www.franklin.com/manuals/twe-118/twe-118english.pdf and if you go to page 5 it explains how to set the date and time.
Hope this helps, and good luck DJRYDR
Posted on Jul 27, 2011
cartridge138
Andrew Henderson
  • 394 Answers
SOURCE: Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Posted on Feb 06, 2015
biffbouncer
  • 5 Answers
SOURCE: Is the Best By date the same as an expiration date?
No, best buy date guarantees the product to be at it's best at purchase by said date.
Posted on Nov 24, 2017
How do I reorder meds?
For meds, the pharmacy name and phone number are on the bottle or box. Also, the number of refills is listed as is the prescription expiration date. You can refill as long as the refill number is not zero and the prescription has not expired.
Note: this is different the expiration date of the medication itself which may also be listed on the label. Please ask your pharmacist to explain anything this is not clear to you..
Sometimes certain meds come in a box and the box with the reorder info is thrown away. Call your pharmacy or your doctor to find out this info.
For medical supplies, some are prescribed so the same information above applies. If they were not prescribed then you can replace them at a pharmacy, medical supply store or on-line. http://www.chaindrugreview.com/_assets/image/ScriptPro%20label%20QR%20code.jpg
Oct 13, 2014 | Medical
Tip
The best before date on bottled water
Water seems like a commodity that can't go bad, so what is up with the best before dates that companies are printing on their labels? Do they really mean anything?
After some research I have found that there is no rule from the FDA that water bottle companies are required to print a best before date. What these dates indicate is that the best quality of the water will be before this date. You will find that when you put water in a bottle after a few days or a while the water will start to taste a little different.
Some times if the water tastes different after the best before date this is an indicator of the chemicals from the plastic leaching into the water. This causes some health concerns, but the chemicals don't really need a lot of time to leach into the water. You will notice that nothing grows in a sealed water bottle but within 2 weeks of opening it you should drink it or toss it because it can start to grow bacteria or mold.
on Oct 27, 2013 | Wine & Spirits
Where do I find expiration date on Orthodox Rose Pride disease control
The best way to get that information is to call the number on the bottle and give them the lot number located on the bottle.
Apr 12, 2014 | Ortho 1pt Rose Pride Disease Control...
What does food expiration code AUG06215H53 mean?
That could mean august 2006 but read up on expiration codes. There are fine articles on the amount of waste of food in the modern world. Alot of it is from lack of knowledge or the quest to only eat the finest freshest newest and leave the rest for the middle and lower classes or dispose of or use for cattle feed. The truth is that the date codes or best before dates are for the supermarket to know when to put the newer foods with the newer marketing strategies up on the shelves. It may be expired for them but not for the consumer. At times it may be expired but only because the colour may start to change or it may not represent the company the best. Some who go to extremes may argue that there is less nutrition if a product isn't the freshest. Some argue that any processing at all has already ruined the nutrition. I say you can eat these products even 7 years past the due date. Canned goods can be good even 20 years later. Try making the meal. Once you open it smell for mold or an off smell... if so discard. During war times or famine many would love to have even that.
Nov 15, 2013 | GOYA Spanish Style Yellow Rice, 14 oz Pack...
Expiration date
Most car seats have a six year expiration from the date of manufacture (not first use). Some seats may have an expiration date on a label, or may have an expiration date embossed into the plastic. To be certain, call the manufacturer. In the USA, call 800-544-1108 (Dorel Juvenile Group).
There are several recalls on the 22-150 model. See www.carseat.org and click on "recalls."
Jun 19, 2013 | Cosco Alpha Omega 22-150
Experation
Pet food in tins, technically doesn't have a Use By Date, but it does have a Best Before Date. You can find it printed on the bottom of the tin, it will look like this- BBD : 221015 23:02 (which translates to Best Before the 22nd Oct 2015) I believe the 24hr time stamp is relative to the production of the tin, not the BBD.
Apr 29, 2013 | Fancy Feast Cats
Is the detection of Hollister coupons easy?
The detection of Hollister coupons is really simple, each of the promotion code maintains its expire and validation date, therefore if there is not mentioned the expire date or the reason for not mentioning the expire date, it is best to know that the promotion code could be useless, but without doubts the reputation of the website you are located is highly important. There may be not mentioned the expire date, but still you exactly know that the website is highly trusty. Thus without the researches we're capable of getting the money off coupons by using coupon toolbars
Oct 17, 2012 | couponseven.com Computers & Internet
Snug Seat Gorilla Car seat
there are no such thing as expiration dates for car seats but I would check with the manufaturer for recalls and also maybe consumer reports or the bbb
Sep 21, 2009 | Snug Seat Baby Gear
How can I insall Themes on E63 When I Install it. It shows Certificate Expired
Certificate expired is when the theme has expired, best thing to do is look at the date of the theme before you download it so you won't have this problem.
Try mobile9 website they show the expire dates
Good luck
Apr 23, 2009 | Cell Phones
Kitchen Appliances - Others Logo
218 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
