Nissan throttle position sensor collects data on how hard you’re pushing the gas pedal, then relays this information to the ECU so it can tell the TCM which shift program to use, and what gear the transmission should be in. A P1705 OBDII trouble code means that there is either a short in the circuit, or the throttle position sensor itself has failed.
Hi. I have a Mirage II A3 scanner that was working fine till I save it in a closet a few years ago. Now I need it again, but I don´t have the PC I used to have with ISA port...
I finally found a brand new PCI card I had in another Umax scanner, so I connected it to the PCI slot in my actual PC. And I cannot connect the scanner... I installed the software correctly, but in Test mode, it gives me a Link failure. Besides, the scanner does its setup when powered on, the lamp goes from right to left, stays there a few seconds and return to its original position. But the UTA and READY lamps keep blinking...
I found this page:https://ask.adaptec.com/app/answers/detail/a_id/1869/~/scanner-test-link-failures-with-umax-scanner, that explains this can be fixed upgrading the software, but the link does no longer exist...
Could you please send me the software I need to connect it..? It´s really important I can do this. I have a huge job to do but it doesn´t work... I´l be waiting for your answer. THANKS!!
SOURCE: Problem installing umax astra 3400 on xp professional
Make sure you have the drivers for xp. If your unsure you can google them and be able to pull them up. try that and that should take care of the issue.Thank you for using Fixya.com
John C
SOURCE: Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
I found this page:https://ask.adaptec.com/app/answers/deta... that explains this can be fixed upgrading the software, but the link does no longer exist...
