SOURCE: Lifestyle 50 "No Response"
The remote problem is same with me and need to repair.
I gots information from Bose Service Center, PCB transmitter and receiver not working well.
maybe this information helpful for you.
tq.
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Testimonial: "Excellent! It works, many thanks for your help"
SOURCE: my panasonic viera plasma TH-42PX80U
Hi:
You will need to count the number of red led blinks on the power indicator, if it is at least 10 then replace the power supply it is faulty, In my years of servicing panasonic Plasma, power supply failure is about the most common failue in this class of television from this manufacture.
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
