Drains then stops and rinse light flashes
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
SOURCE: washer not draining and rinsing
Hello Wet Towels, well to be honest outside of the test program I have never seen a fault code E13. If it was an error E03 I would check my water to make sure it was turned on, the cold inlet hose wasn't pinched, or debre filling the filter screens in the hose or water valve. That is what the care and use says about E03. In the back of your owners manual it tells you what the fault means and how to correct it. If this doesn't work call for service to resolve your issue. Hope this helps.
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: inlet/drain, salt and rinse aid light flashing
Hi
Thanks for using FixYa. The first
thing that should be checked is if its draining properly as it could be that
the drain hose is clogged and needs to be cleaned. The drain pump also should
not be clogged. Also the stopcock should be opened fully and the water inlet
valve should be checked for any clogs. Also the metal
filter, impeller cover and the air gap unit should be checked. After
checking this you can reset the error as follows: turn the
rotary selector switch to "Stop/End" or press the "Start/Stop"
switch for approx. 5 secs. Then switch the appliance off and then back on
again. Please do rate the solution if the issue is resolved or else revert
for further assistance.
Thanks
Rylee
