Question about Sony Office Equipment & Supplies
Sony VPL-CS4 Hello., My projector is not displaying anything even after replacing lamp. Stand by shows green, fan works fine.... But projector light /display is not turning on. Please help me in resolving this issue. Thank you,
5 Related Answers
stilyou
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
Marrie
Marnus Jacobs
  • 563 Answers
SOURCE: In Focus X2 projector won't display welcome screen
Hi there
Is it only the Welcome screen that doesn't work ? Or doesn't the Projector show a image at all ?
Posted on Mar 27, 2008
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: Please replace the lamp
On your remote,push these 4 buttons in this order.
RESET < > ENTER
Posted on Jan 12, 2009
ABRsvcs
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Green light is continuesly bling but the projector is not given the display
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Dec 11, 2014 | Sony VPL-BW5, VPL-ES5, VPL-EW5, VPL-EX5,...
I replace one new lamp C121 but no power in my projecteur lamp
the thermal fuse 1-900-222-47 could be the issue see service manual
Jul 23, 2012 | Sony VPL CS4 Multimedia Projector
VPL-CS4
Projector on Standby, press RESET, <<=, ==>, ENTER to reset lamp timer.
May 14, 2009 | Sony VPL CS4 Multimedia Projector
Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
Apr 18, 2009 | Office Equipment & Supplies
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Jul 06, 2008 | Sony VPL-DS100 Multimedia Projector
SONY VPL-CS3
Hi there
Replacing the lamp won't make any difference at all.
If you have checked the fuse on the Powersupply Board and it tested ok , then the whole Board will need replacement.
Apr 29, 2008 | Sony LMP-C121 Projector Lamp for VPL-CS3,...
Lampcover brightining
Hi there
Your Projector needs a new lamp and do remember to reset the lamp timer after replacing the lamp .
Mar 24, 2008 | Sony VPL CS4 Multimedia Projector
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
