Lexmark X7350 All-In-One InkJet Printer Logo
Question about Lexmark X7350 All-In-One InkJet Printer
How can I install Lexmark Printer model X7350 without a Disk to Windows 10 on my new computer?
Posted by Dave on
5 Related Answers
Anonymous
SOURCE: Lost installation disk
I have misplaced my installation disk for Lexmark/Z600...Model #4126-K03. Can I download it from internet??????
thanks/fish
Posted on Feb 09, 2008
Anonymous
SOURCE: Can't install my Lexmark Z640 printer. No installation disk.
Can Not Install my Z640 Printer
Posted on Sep 24, 2008
marked
Mark Gil
  • 6487 Answers
SOURCE: i lost my lexmark x2600 installation disk
You can go to this link and download the software for your printer, just select the operating system that you're using on your computer http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:92:0:0
Hope that helps..........
Posted on Oct 07, 2008
Anonymous
  • 70 Answers
SOURCE: Need to install Lexmark X7350.Printer
You can dload the installation drivers for your printer here
Just make sure you select the OS you are using.
GoodLuck
Sean
Posted on Feb 23, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: how to install lexmark 3500=4500 series printer without setup disk
To all Lexmark owners with the lost disk problem.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
If you instead want to purchase a new disk, bear in mind that Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Posted on Apr 07, 2009
I have a Lexmark x7350 connected to a PC running Win7. I have previously been able to print with this combo with no problems at all. I have removed the device, uninstalled the Lexmark software, rebooted,...
Please follow the steps on to properly Uninstall Lexmark Printers from your computer. After the uninstallation process is done, reboot pc when prompted.
When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the link below to download and install the Lexmark X7350 Printer Driver on your computer. Note: Use the Vista Driver on Windows 7. - Lexmark X7350 Driver for Vista 32-bit - Lexmark X7350 Driver for Vista 64-bit
When the installation process is successful, try to print a document to verify that the problem is fixed.
New laptop with windows 7 won't print to Lexmark x7350. says to enable bidirectional support - but that option is grayed out.
Make sure to use the correct printer driver version for your operating system. You may need to uninstall your existing printer driver first before downloading the new driver. Go to Start menu > Programs > Lexmark 7300 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
When your computer turns on, go to Start menu > right-click on Computer > Properties. Check the System Type. Note: Use Vista driver in Windows 7.
Use the links below to download and install the printer driver: - Lexmark X7350 Driver for Vista/Win7 32-bit - Lexmark X7350 Driver for Vista/Win7 64-bit
Follow the instructions on your computer screen.
1helpful
How to install the x7350 printer without disk
Improve the Fixya.com experience for everyone by voting!
I suggest that you download the driver and therefore have no need for a disk. (Windows 7 will automatically find the X7350 and install the driver) For Windows 2000, NT, and XP click on the following link and start you download. Lexmark Drivers for Model X7350
All the best
Ben
Installing printer without disk
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
26helpful
3answers
Lexmark 7300 series I need Windows 7 drivers it wont work with my new computer
Hi daybreaker69
lexmark 7300 series drivers (win7/win8) can be found at
driverupdate us . (32/64 bit)
It will take 2 mins from you to install... after updating, go to word and try to print something
I hope I have helped you...
enjoy
How can I download Lexmarx X7350 to my new computer??? It is a notebook with no disk drive?
The Lexmark X7350 printer is compatible with Windows operating system only. You can download the driver from the Lexmark website at http://bit.ly/9zceAX. Choose the right driver for your operating system. Use the Vista driver in Windows 7. Thank you for being a Lexmark customer.
Lost my disk , can i use to perform a free download for lexmark x7350
There are Microsoft drivers available for download in the Lexmark website. Before downloading, if your using Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by going to Start Menu > right click on Computer > Properties. Actually, there are no drivers for Windows 7 but Vista drivers are compatible with it. To download, just click on this link: http://bit.ly/9zceAX . Choose the correct driver compatible with your computer's operating system. Download and install the software.
5helpful
2answers
Lexmark x7350 , don't have install. disc need to install printer to new computer
Hi
You can download the drivers and software from www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
Lexmark X7350 InkJet printer & Vista
Follow this link to Lexmark site, uninstall your old driver before installing this one to see if it corrects the problem
Top Lexmark Office Equipment & Supplies Experts
Marvin
Marvin
Mehandi Husain ...
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
