SOURCE: Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
SOURCE: My Logitech Alto Cordless Laptop Stand Keyboard stopped working
Have you tried the connect button underneath the keyboard? Sometimes they get out of sync.
You will have to press the sync button on the stand first and then press the sync button on the keyboard. Good Luck
if its a wireless mouse and keyboard make sure the batteries are securely seated and fully charged the battery panel should be on the underside of your mouse keyboard as would be the on off switch
click start control panel keyboard hardware make sure the right type of keyboard is selected
click start control panel keyboard hardware troubleshoot or click start control panel administration tools computer management device manager scroll to keyboard you could see a yellow question/exclamation mark ? ! or red X a new driver will need to be installed
right click to install drivers
http://download.cnet.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
hope this help
