Question about APC Computers & Internet
Error code on apc smart ups showing 02000 - APC Computers & Internet
Posted by mbuh eugene sama on
5 Related Answers
Jesrey Paco-in
  • 91 Answers
SOURCE: APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Posted on Aug 14, 2009
SOURCE: how to connect a UPS to a computer? why some UPS
A UPS goes between the Power Socket and the PC equipment.
So ya can "Talk" to the UPS and change monitor settings. So do some don't depends wat ya want?
A "Smart" one is computer controlled, and most probably ya can "Talk" to it, the other is the "Vanilla" model, real plain.
More Complex.
Posted on Jan 26, 2010
Anonymous
  • 25 Answers
SOURCE: APC smart UPS
Check mosfet.
Posted on Mar 09, 2010
Anonymous
SOURCE: smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Posted on Aug 26, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Posted on Dec 08, 2011
Our 5000VA smart APC ups showing this error: Power system error 02000.What does it mean and how do I overcome this?
Best thing about this new service is that you are HELP NUMBER +1 833 272 0777never placed on hold and get to talk to real repairmen in the US.
Jun 20, 2017 | APC Computers & Internet
APC SURTD3000XLI UPS error light, 2 battery lights no output
check the fan in the back .... try to replace if damaged
Nov 13, 2013 | APC Smart-UPS RT 3000VA UPS System
Hi, We have purchased some APC 10KVa Smart UPSes and the firstone, when wired up to a single phase 63A supply, shows an internal fault (Red X) and battery lights 1 and 4 are on. This looks like a code...
The manual for your model APC UPS is available from their WEB site. Go to this WEB site for the info. your require.
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUrt10000xli
May 09, 2011 | APC Computers & Internet
Smart apc ups error with all indicator flashing .
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
Hi my APC 1500VA smart UPS show overload without any load in battery mode, but when switched on AC power all lights are blinking. plz describe me how to resolve this Issue?
Contact APC Customer Service. They will help you resolve this. If unit is still under warranty they will replace it. There is nothing you can do to repair anything yourself. Sorry ... try calling 1-800-555-2725800-555-2725 for support from APC
May 06, 2010 | APC Smart-UPS 1500VA Shipboard...
Way to reset the user name/password
only thing i ran into was this: try it.
Default Password for APC Smart UPS
Description
Manufacturer APC Protocol Multi Access Admin Model Smart UPS User ID apc Password apc
Feb 19, 2010 | Enterasys APC Smart-UPS 2200 XL...
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC smart UPS
APC is not really the best product, and if it did have a problem like have, at such a small desposable size, your best soluiton is get another one, and a better brand.
www.storminprotection.com check out my page that should help you. You overloaded your system and did damage it prior to the fact that now it shows over load all the time. Get a bigger unit.
Sep 15, 2008 | APC Smart-UPS UPS System
Computers & Internet Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Joe Goldman
Joe Goldman
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
