Question about Bernina Sewing Machines
My Bernina 801 is stuck in the tack stitch. How do I get the regular stitch back??
Something happened when I did a reverse stitch - I don't know what I did, but now the only way to sew a straight line is to hold down the stitch regulator know while sewing. HELP.
Posted by S.j. Anderson on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
Hm, am wondering if it is seizing. How long since it has had a thorough clean and oil? Seizing happens when the old oil dries and begins to stick the machine parts.
Wheel on right side that controls the needle up and down is very tight...
Posted on Dec 06, 2017
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
Anonymous
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
Anonymous
  • 21 Answers
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Posted on Sep 21, 2008
Anonymous
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
Anonymous
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
Bernina 830: When making a buttonhole... the zigzag #1 stitch on left side looks nice... then the #2 bottom bar tack looks good...
Please tell us which Bernina 830 you have--old mechanical Record or new computerized?
Here's a recommendation from a Bernina owner (Ellen Rosenthal on Yahoo Group "BonosBerninas":
I agree about the buttonholer. The reverse stitching never looks as good as the left or forward side. I “hack” this by pivoting my fabric and only
going forward-avoiding the reverse stitch. Also helps to do the whole process twice and to use some tear away or wash away interfacing.
There is another Yahoo group called "BerninaThirtySomethings" that is a great resource.
Jan 25, 2018 | Bernina Sewing Machines
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
Needle won't go up and Down
Is this a Bernina machine with the needle stuck in the up position? If so, is the model something like a 930 or 1030 or similar?
I'll have a go at an answer but unless you give more information than this, it's not worth attempting.
Oct 17, 2014 | Sewing Machines
Bernina activa 210/how do i switch reverse sewing back to statight stitch
Perhaps the manual would be helpful:
BERNINA activa 210 Support BERNINA
You may want to download and keep this manual. A lot of manuals for older Berninas are no longer available.
Dec 15, 2013 | Bernina Activa 130
Stitch selection 3,5,6, and 7 stopped working on my bernina sport 801. These selection all become stitch type number 4
the gear or cam that makes these stitch or stitches could be worn or damaged, the part would have to be replaced.
Sep 07, 2013 | Sewing Machines
Bernina 1130 backstitch is not working
then you need to call the shop that serviced the machine & tell them
about the problem that the machine won't backstitch & see what they
say
Apr 29, 2012 | Bernina Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
I have been using a long stitch length to gather a lot of tulle. Now when I go back to a regular stitch length it is still long or it varies as I am sewing. Also it will not sew in reverse.
Try going to your Bernina dealer and see if they have any suggestions because they can evaluate if it is serious or just a simple adjustment. You have a great brand and you do not need to have it messed up by not having someone try to fix it when they do not have the right tools or know how. It may be due for a simple tuneup.
Sep 19, 2010 | Bernina Sewing Machines
Auto buttonholer problem singer 2662
You do need to adjust your stitch length to get the satin stitch look. Also, some of the auto buttonholers require you to reset the lever after each buttonhole to restart it.
Feb 01, 2009 | Singer 2662
Sewing Machines Logo
145 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
