Health & Beauty Logo
h
harry fitzner Posted on Dec 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No slow speed, only fast speed
When starting out, the chair is in fast speed only, cannot start out in slow speed
fyigen
Level 2:
Habit-Forming:
  • Expert 145 Answers
  • Posted on Dec 06, 2017
fyigen
Expert
Level 2:
Habit-Forming:
Answers
145
Questions
Helped
29066
Points
456
Always state your MAKE and MODEL when asking for help with regards to your product or item.
5 Related Answers
Anonymous
  • 100 Answers
  • Posted on Oct 21, 2008
SOURCE: When I start my jaguar,
if it is a v12, and at idle when warm if it goes up and down then you need to rebalance the throttles, they are off balance causing the idle to raise and drop.
set the butteryflys behind the air cleaners to 2 thousands of an inch using a fella guage and make sure the linkage arms from the pedestal in the middle of the engine are set the same (one is not longer than the other)
JPTCAT
Anonymous
  • 58 Answers
  • Posted on Sep 04, 2009
SOURCE: playback is too fast using Pinnacle Quick start version 10
This sounds like a Frames per second setting issue.
Just a guess, but you recorded at 15 FPS & the player is regurgitating at 24 (or 30) fps.
Anonymous
  • 945 Answers
  • Posted on Oct 15, 2009
SOURCE: chair runs to fast in high speed. can it be slowed
If you can alter the speed, there will be a dial on the armrests to turn it down, i presume you have 4mph and 8mph,the dial will adjust the speed , so that it takes longer to reach 8mph.
Anonymous
  • 130 Answers
  • Posted on Apr 19, 2010
SOURCE: Kitchenaid K45SSWH Mixer only starts fast then sometime slows
You can try adjusting the speed control as shown in section 6 of the service manual:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Also remove and clean the brushes as shown in the same manual pg 8 fig. #30.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on May 15, 2010
SOURCE: mower runs at slow speed only
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
My chair flashes a ! Symbol and looses power
Make and model may help you get an answer
My power chair is so slow, not sure what the speed is but, its slower then walking pace.
check with your operators manual and you may find a switch that has the markings of a hare on one side and a tortoise on the other
that will be you low and high speed settings
I have a pronto M61. Forward speed is very slow even when adjusted to higher speeds. Turning speed increases normally. Is there a problem in the joystick?
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
How do I speed up a Merit Vision Sport?
As the user of the chair, you will not have the ability to speed up your chair unless you have the specific programmer to raise the speed. Typically mobility specialist will turn your speeds down until you get used to the chair and then come back out when you are capable of driving chair at faster speeds. You will have to call the dealer who slowed it down or, another DME company in your area to have the chair speed adjusted.
Pride Motor Chair 2008 Vr2 Controller Speed adjustment lights go to fast setting but chair barely crawls along!
Great question! The slow flash is indicative of a speed reduced mode on models designed for a seat lift option. If the controller detects that the seat is elevated then the speed is reduced - regardless of what you try to do at the joystick.
First - try lowering the seat to its lowest position.
If this doesnt work then look for a bad or disconnected sensor switch on the seat post. There are two leads at a 2-pin plug that are not making a connection when the seat is lowered - causing the controller to sense the chair is not safe to drive fast.
How do we lock out the fast speed on grandpa's chair so he doesn't hurt anyone?
Ann You will have to contact the provider of Gramp's chair to ask if they have a programmer for Invacare chairs. Then they will have to program the chair for a lower speed. Of course you can turn the speed down on the joystick but Grandpa is probably the one that will put it back to fast cause its going too slow. try also contacting Roadrunner Mobility@ 1-800-467-2668 and ask if they have a tech in your area that has a progeammer to slow his chair down. Hope this helps
3helpful
2answers
Have just purchased a Jet 2 power chair. The top speed is less than walking speed. Is this normal or is there some thing wrong?
Sandy Well could be. Hows that for an answer? It depends on the batteries and the speed setting. If the batteries are getting weak then they won't drive the chair as fast as new or good batteries. If the speed is not set to max then it won't go as fast as you like You can set the speed on the joystick. Now if the speed is set to max and you are still going slow and the batteries are new or good then it could be the program. Check with a provider(Person or Company that sells chairs) in your area and ask if they can check the programmed settings for you. If they have a PP1 programmer they should be able to easily check the settings and adjust them higher if they aren't already set there. Good Luck Hope this helps you
1helpful
To slow, i need it to go faster
Are your batteries fully charged? Are the batteries 2 years old or older? Even with a full charge older batteries will not generate amperage to make the chair go as fast as when new. Also the motors tend to slow down with age due to brushes wearing down. Now, if the batteries are new and the motors are not that old then you need to find a wheelchair provider that has a PP1 programmer and have then check the settings for forward speed etc. If the speed is not set to 100 then they can increase the forward speed to 100%. Hope this helps you
Reverse speed too high
No, the controller must be reprogrammed and you will need an Invacare service tech to bring his hand-held programmer over to make the corrections to the chair.
Chair runs to fast in high speed. can it be slowed down
Top The Health & Beauty Experts
Paul Carew
Steve Sweetleaf
Steve Sweetleaf
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
