I fixed the problem myself. I got tired of the loud fan behind it keeping it cool. Here is how I did it.
Turn off the power and remove the monitor from the stand. Lay it on its face and remove the 4 black screws in the middle around the mounting surface for the stand. Flip it over and carefully pry the front away from the back . "BE CAREFUL NOT TO PULL TOO FAR AWAY AS YOU WILL DAMAGE THE CABLE TO THE BUTTONS"
Once the front bezel is free all the way around flip the monitor over onto its face. The back cover should slide off. Remove 8 screws holding 3 metal covers guarding the electronic boards. The right board slides to the right before lifting out. Once all 3 have been removed you will see the guts of the monitor. Find the heat sinks on the power supply. They will be covered in dust if they are like mine were. I used a Brush and can of Air to get them all clean.
Now for increasing the airflow up through the Hot stuff. I used a Dremel Tool to enlarge the holes already in the back plate and Cut out a hole in the back cover to let more air in. Its not pretty but it works.
Now remount it on the stand, Hook it up, and it should " cross your fingers " work.
