SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked. the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
SOURCE: My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
Posted on May 13, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
