Question about The Audio Players & Recorders
Hi, we have a high definition multi-media karaoke player but if we press enter in karaoke, the select song will not appear... We just bought it in less than a month. Please help us.
Posted by Joy Agraciada on
Clive
  • The Master
  • 882 Answers
Hi Joy.
To help you further, people need to know the make and model, as they differ from one unit to another.
If less than month, surely it still has a guarantee?
Otherwise ask the friendly sales staff at the store where it was bought - it may just be operator error.
Posted on Dec 04, 2017
5 Related Answers
Shayne Schecht
  • 146 Answers
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
Posted on Jan 03, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: ringtone file corrupted
pls go to start >Programs>fileExplorer>select music file u want to set as ringtone, and then long tap on the file for like 4 sec a menu will appear u can select set as ringtone and ur file will be set it is the std procedure for it
if it helps then fine otherwise
pls try resetting the device but first backup all data bcoz all programs and data will be lost in this process kindly backup first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
pls rate me FIXYA foir this
Posted on Mar 07, 2009
Anonymous
SOURCE: sony N50....digital media player....NW-A805
i cannot connet my sony to my computer to download music from the net,when i set it up screen on the sony says connecting but does not
Posted on Mar 24, 2009
Anonymous
SOURCE: Mediacom Karaoke Player MCI DVD 3000 Pro
Mediacom Karaoke Player MCI DVD 3000 Pro In India where it can be obtainad ?
Posted on Apr 23, 2010
saeedanwar84
SOURCE: keypad problem
hi my n73 keypad is nt working' all keys nt work
Posted on Aug 16, 2011
Hdv-206 hyundai karaoke problem
Hi, I have a karaoke player HDV206, I'm facing problem when I insert the karaoke disc it shows in the screen "PROTECTION FAIL" and I cannot select any songs from the songs list. Hope I can get solution.
thanks a lot.
Jun 19, 2011 | Audio Players & Recorders
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
Apr 29, 2011 | Audio Players & Recorders
Hybrid megavision karaoke upgrade
I would like to add some new songs for my megavison hdd multi karaoke jukebox... can anyone show me how and tell me where i can download songs or videoke songs...
Feb 16, 2011 | Audio Players & Recorders
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
Hi I have windows7 on my laptop. I am unable to remove songs from my Scandisk. Media player also should be latest. Can you guide me how to remove or add songs in my e260 .
By pressing and holding the Select button while listening tomusic, the player will automatically detect whether the current song isalready in the "Favorite List" and guide you to add/remove the songfrom the Favorite list.
STEP 1 - Enable "Advanced mode"
1. From the Main menu, select Settings > Advanced
2. Select On.
STEP 2 - Add song to the "Favorite List"
1. During music playback, press and hold the Select button.
NOTE: If the song is in not in the list, a confirmation message for adding the song to the list will be shown.
2. To add, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
STEP 3 - Remove a song from the "Favorite List"
1. During playback, press and hold the Select button.
NOTE: If the song is already in the list, a confirmation message for removing the song from the list will be shown.
2. To remove, press the Select button when the check box is highlighted. To cancel, press the |<< button to highlight X check box then press the Select button.
Feb 26, 2010 | SanDisk Sansa e260 MP3 Player
How can I ''shuffle''my songs on sylvania's smpk4083 model?
The SMPK4083 can shuflle songs, selecting Random:
Follow next procedure:
In PLAYING mode, press M while playing music to enter
the selection menu screen.
Choose Repeat and press M to enter the Repeat menu screen.
Next go to Random using |<< / >>| buttons, while selected Random, press M to choose for random play.
Jan 23, 2010 | Sylvania Audio Players & Recorders
How can I title my songs?
You have to right-click each song in Windows Media Player, select "Advanced Tag Editior," and manually enter the song names in some cases (or select "Find Album Info" and acquire the info). Any songs that you edit in Windows Media Player will have to be deleted off of your mp3 player, and then re-added, or else it will not save the changes.
Mar 26, 2009 | GPX ML648B MP3 Player
Unlock Code
http://www.digitalfaq.com/downloads/dvdhackarchive/lg5000.zip
Unpack the zip file and burn the folder to a disc.
I used Nero...
1. Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order.
2. Insert the disk to your player
3. It loads..... After a few seconds it opens the tray
4. And a Region Select menu will come up.
5. Press "0" on the remote for multi-region. Then press the pause key (or maybe the enter key).
* Region 0 MUST appear in both of the definitions on screen
OR
Power on
wait "no disk" to appear
open tray
press 0 four times
"region edit" and "region code" appear with the default code
press 0 for region free
enter
"region code" should now be 0
pause
power off
Jun 30, 2008 | LG Televison & Video
I cant delete any songs off of a MyMusix PD-6110 MP3 player....
Q: How do I delete songs from the PD-6110?
A :The songs only can deleted through your PC. If you use Windows Media Player 10, go to the Sync window and select the songs that should show up under the 'Music' folder tree on the right side of the window and select the songs you want to delete and press the 'delete' key on your keyboard. With Windows Media Player 11, Open the 'MP3 Player' tree on the left side of the window then select 'Songs' from the list. Then select the songs you want to delete and press the 'delete' key on your keyboard. You can also open the 'Removable Disk' under 'My Computer' and delete the songs from there.
Nov 26, 2007 | Audio Players & Recorders
43 people viewed this question
Top The Audio Players & Recorders Experts
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
Michael Roth
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
