Question about FUJIFILM Cameras
Hello Edward.
What mount does it use?
Bayonet-type K-mount?
Screw mount?
Can you supply a photo or graphic of mount?
Posted on Dec 04, 2017
SOURCE: ol' Vivitar 200mm telephoto lens
Is this the same lense that you have?
http://www.mflenses.com/gallery/v/lensgallery/japanese/vivitar/vivitar/prime/vivitar200mm_f3_5-1.JPG.html
Posted on May 01, 2008
SOURCE: conversion lenses & filters
These screw on the front of the plastic lens adapter and adjust the focal length. On the side of the adapter lenses it will quote the ratio. My wide angle says 0.66x so just multiply the range of focal lengths by this figure and you will see that it adjusts the camera zoom accordingly - making the image wider and probably also increasing the depth of field (what is in focus). Similarly a 1.5 tele will inrease the range of focal lengths to make the lens "longer" eg higher magnification , useful for astro photography - shots of the moon and terrestrial long distance work but detracting from the depth of field, eg the range of distance over which objects are in focus will be reduced.
The wide angle will allow you to come in close and get WIDE objects fully in-frame- hence "wide angle", while the telephoto will give you better overall maginification of the image but will probably increase the MINIMUM focal length - eg you may not be able to focus on objects closer than >2m (instead of ~1).
The screw-on adapter lenses I found were cheap in a Jessops sale use a 52mm thread, while the S5500 provides a 55mm internal thread. I use an appropriate 55mm to 52mm step down ring adapter. There is slight vignetting (shading around the edge of an image) at certain combinations of zoom, but generally these are very useful accessories.
As these are adapter lenses on the front of an already powerful 10x zoom that must be optically compromised at the price of this camera, there maybe some colour fringeing around bright images. If you want a better solution you really need to get a DSLR. Overall a good solution for the price.
Posted on Oct 06, 2008
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
SOURCE: I'd like to purchase a micro lens for my Nikon
If the Phoenix lens is autofocus (AF) in Nikon mount, it will work with the D90. You may find that you want to switch to manual focus when you are using it for macro shots for better control of focus. It will still set exposure properly when set to manual focus.
Posted on Apr 04, 2009
SOURCE: Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Posted on Jun 12, 2009
Apr 29, 2017 | Nikon Cameras
Apr 28, 2013 | Canon Zoom Telephoto EF 80-200 f/4.5-5.6...
Feb 08, 2013 | Opteka 650-2600mm High Definition...
May 25, 2011 | Opteka (OPT2XTE5000) for Fuji Finepix...
Jan 28, 2011 | Opteka 650-2600mm High Definition...
Jan 19, 2011 | Opteka 650-2600mm High Definition...
Nov 24, 2010 | Opteka 650-2600mm High Definition...
Jul 19, 2010 | Opteka 650-2600mm High Definition...
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
Mar 17, 2009 | Nikon D40X Digital SLR Camera Digital...
51 people viewed this question
