Most washers will not unlock the door if it senses any water inside, select drain and spin or rinse and spin to rinse the clothes and drain the water. Once it has completed the cycle the door should unlock. If it does not there is usually an emergency release on the look lock inside the machine by removing the top or front panel.
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
SOURCE: euro tech front load washing machine
YOU CANNOT RESET ERROR CODES ON APPLIANCES BY MERELY UNPLUGGING THEM FOR 5 MINUTES. MOST MANUFACTURERS RECOMMEND AT LEAST 30 MINUTES IF YOU GOING TO ATTEMPT TO TRY TO RESET A COMPUTERIZED CONTROL BOARD. STOP POSTING THIS INFORMATION INCORRECTLY.
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
SOURCE: Cant open the door on my washing machine
if you can get a small thin metal object in there and jiggle it around, you may get it open. if not, sheet metal panels will have to be removed to get to there. do not smash the glass!
SOURCE: Washing machine front loading door won't open.
that is the way it's made you have to turn it off before you can open it or water would go every where.
