Question about The Office Equipment & Supplies
SOURCE: Adding adding machine paper to the Ibico 1202
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in..Look in the back of the printer for a thin slot. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Please remember to leave a rating or feedback if I have helped you with your question.
Posted on Mar 21, 2008
SOURCE: Why oh Why>
Because this is an adding machine you would use the total button (*) not the = for ading and subtracting the = is only used in multiplcation and division
Posted on Apr 29, 2008
SOURCE: How do I get this calculator to substract
Big calculators work a little different than handheld calculators. Like the above commentor explained, if you have a basic "whats 100 minus 20?" You have to entered as 100 + 20 -- And when you hit the minus button at the end, it will give you the total. 100 is the positive number, and the 20 is the negative number that your subtracting. Also you can hit 20 -- 100 + and get the same total because you entering 20 as the negative and 100 as the positive, just in reverse.
Posted on Aug 24, 2009
SOURCE: I have a TI-30XS Calculator
One solution that you might try is to put the scientific numbers in parentheses. For instance open parenthesis, type in the first scientific notation then close parenthesis, next hit the divide key and then open parenthesis and type in the 2nd number in scientific that you are dividing by and then close parenthesis. Hit enter or =. I'm not sure if this will fix your problem, but it is worth a try.
Posted on Aug 29, 2009
SOURCE: how do you subtract
Its a little strange. Suppose you want subtract 10 from 38. Do this:
Enter 38 press plus key.
Enter 10, press minus key.
Press the equal sign. You will have the result.
Posted on Oct 22, 2009
Sep 13, 2016 | Staples SPL-P500 Printing Calculator
Oct 08, 2013 | Sharp el-531x scientific calculator
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
Feb 06, 2011 | Canon Office Equipment & Supplies
Jul 12, 2010 | HP Computers & Internet
Sep 25, 2009 | Victor 1208-2 Calculator
Jul 22, 2008 | HP LaserJet 4 plus Printer
Jun 06, 2008 | Canon P23-DHV Calculator
Dec 08, 2007 | Office Equipment & Supplies
