SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: VGA port connection to old style TV
Right click an empty spot on your desktop, select properties. Click the Settings tab. Right click the gray-ed out monitor, select enable.
To push the image to that screen, press the Function (FN) key and F4 normally.
SOURCE: how can i connect my toshiba laptop to toshiba tv with vga to rca
Go to Toshiba site or send email to UK office help.
Requesting the info.
Or type in toshiba to google and surk for the info, it is there.
SOURCE: trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
SOURCE: When I connect my Toshiba
Try pushing the FN button, next to the left CTRL button, and then hit the F5 key at the top. By the number of times you hit the F5 button, you are telling the computer to display on its lcd screen, on the monitor (TV), both, or neither.
