Question about Crosley Audio Players & Recorders
Crosley troubadour stops before record is done
I have an extensive 33 1/3 classical record collection, but the player stops prior to the end of the record.
Posted by Carol Cunningham on
Bill Willard
    New Friend:
  • 48 Answers
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
Posted on Dec 03, 2017
5 Related Answers
Anonymous
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
Anonymous
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
Anonymous
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
Anonymous
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
OSU_Matthew
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
My PTCDS1U just started playing too slowly despite my attempts to adjust the speed
Is this a belt drive turntable? If so, replace the belt - its slipping.
Dec 30, 2013 | Pyle Pro - PTCDS1U - Home Ptcds1u...
Hitachi Troubleshooting
Check to see if you have a setting to change between 33 or 45. If set to the wrong setting for the size record you are playing the tone arm will pick up incorrectly.
Nov 16, 2013 | Heating & Cooling
Prior to recording in"stopmode" does
The Stop mode means Power On , Disc in Tray and ready to go ( waiting for next command ).
Apr 23, 2011 | Samsung DVD-HD850 DVD Player
How do i record an instrumental on studio one from youtube
Electronic studio performs the remixing on the sound audio files. For example, display on the computer program the remix software from where several functions makes creating, recording or innovating music productions. usually the progrma mixer allows to create audio either produced to an external area on disk CD DVD else displayed on network sturtures. Prior to creating files on the audio mixing software, determine whether the files at complete version were displayble on CD DVD media else on the network. Several factors require predetermining the location area on where media would be displayed after productions. First, ascertaining that media would be displayed on youtube as an internet website requires to encode the sound as internet loadable. Where for example, the internet least allows entensive sound audio considering spaces available. Second, the internet web sites require compartibility. Where for example a prior determination of loading on the internet makes the formats on which creation is attained. Audio electronic studio has an enormous format record methods that require prior determination to capture the final sound audion files to be made available eslewhere. Familiarise with the audio files on audio requirements. The processes to recording audio files on the program is provided. First, the prorgam has an available method to record where examples of prior audio files allow to remix either into version preferable. Once the program has been displayed, audio windows allows to add files using where several audio clips are integrated from which becomes remixed. Observe the feature functions on the programs tools to capture an extensive remix possibilities. For example, the audio files has the features that allows to record voice that is intergrated to prior instrumental recordings either as piano, guitar or xylophone clips. Obserrve from the prior recorded collection of clips that makes possible remixing. In the sitaution where audio prorgam least has prior collection of intrument clips would require to capture from an elsewhere location either least from the computer to be installed on from where audio captures the experiences of remixing. Once the audio prorgam has been displayed on the computer, explore through the user guide to attain a tor explanation features. Refer also the product manufacturers user guide to attain methods to achieve experiences.
Feb 20, 2011 | PreSonus Audio Electronics Studio One -...
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
May 09, 2010 | Crosley 0187SST Turntable
Playing to the end of the record
I LOVED the 40bs, and if you look at the size selector, which is located at an angle to the right side at the front along with the manual or auto setting in the front. There are 4 settings, 78-10, 45-7, 33-12, and 33-7 for the speeds and sizes of the recordings.
Apr 14, 2009 | Teac AG-V1050 Receiver
Sanyo DVD recoder doesn't play if I let record run to end of disk
most dvd recorders have setting to finalize at the end of a timer generated recording, or to fianalize when the disc reaches the end and runs out of room, check for one or both of these settings in the setup menu of the recorder
Mar 31, 2009 | Sanyo DRW-500 DVD Recorder
DVD copies stop playing after 30 minutes
sounds like a gear is broke moving the transverse motor
Jan 10, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Line in
You need a device that does not come supplied with the player.
Making LINE-IN recordings
Line-in recordings are used to record music tracks in digital format directly from an external player.
1. Connect an external player (like a portable CD player or a stereo system) to your player via the docking
cradle. (this is an optional accessory which is not supplied with your player)
2. Insert one end of the audio cable to the line-out connection on the cradle and the other end to the device
you want to record from.
3. Go to the main menu of your player and select Recordings > Start LINE-IN recording.
4. A message Connect line-in will be displayed.
5. Press 2 to start line-in recording, at the same time, start the playback on the device you want to record from.
6. Press 1 to stop recording.
7. Your line-in recording will be saved on your player as a PCM file (.wav extension). You can find this file
under Recordings > Recordings library > Line-in recordings.
-Tha Mp3 Doctor
Aug 17, 2007 | Philips GoGear HDD6330 MP3 Player
302 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
