Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Posted on Dec 03, 2017
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
SOURCE: When filling my F&Paykel washer
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. [email protected]
Posted on Apr 30, 2008
SOURCE: Smart drive washing machine not filling properly?
There is a valve under the top of the cover were the bowl is This valve has a spring in it and this spring and valve can get stuck shut this stopping the speed of the water entering the machine it may stop it all together
Posted on Apr 03, 2009
SOURCE: water filling issue
It sounds like you have a faulty Out of Balance Micro switch(the machine now thinks it's always out of balance) you'll find this under the motor controller module (main computer module) in the top of the machine on the righthand side. Anymore questions feel free to ask. cheers
Posted on May 15, 2009
SOURCE: Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Posted on Jun 03, 2009
Mar 24, 2017 | Washing Machines
Jun 21, 2017 | Fisher and Paykel (IWL12)
Nov 01, 2012 | Fisher and Paykel Washing Machines
Mar 10, 2012 | Fisher and Paykel Washing Machines
May 20, 2010 | Washing Machines
May 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Feb 20, 2009 | Fisher Paykel Eco IWL16
Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
Oct 24, 2008 | Washing Machines
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
96 people viewed this question
