Watches Logo
S
Sonja Harris Posted on Dec 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset time and date on fit bit watch - Watches
NOEL
Level 3:
Top Expert:
  • Watches Master 8,606 Answers
  • Posted on Dec 03, 2017
NOEL
Watches Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322151
Points
68630
Hi Sonja.
How do I change the time and date on my Fitbit?
  1. From the Fitbit app dashboard, tap or click the Account icon ( ).
  2. Tap or click Advanced Settings.
  3. Tap or click Time Zone.
  4. Turn off the Auto option and select the correct time zone.
  5. Sync your tracker.
Help article: How do I change the time on my tracker? - Fitbit Help
https://help.fitbit.com/articles/en_US/Help_article/1176 Search for: How do I change the time and date on my Fitbit?
or read up more at this link.
How to reset time and date on fit bit watch Google Search
1 Related Answer
small6363
  • 18429 Answers
  • Posted on Jul 27, 2012
SOURCE: reset time and date on armitron watch
download the manual from the link below
http://armitron.com/WatchPDFS/ArmitronLadiesDigital.pdf
I don't know how to set the time on my fit bit watch
you need to sync the fit bit with a Mobile phone or computer and the fit bit will get the time from the device you sync to
Oct 03, 2017 • The Watches
2helpful
How to unlock my heart rate monitor
Tap mode, it will bring up a screen with the date and time on it.then hold reset. The lock will start blinking and then disappear :) It looks like you guys are probably done with this watch but I thought I'd answer anyway. Good luck.
2answers
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
How do you turn the heartrate monitor on?
How do I turn the Heart Rate function on and off on my watch? Within the Date and Time screen, if the heart icon is showing, the heart rate function is on. To turn off the heart rate function, simply hold the Reset button until the heart icon goes away.
28helpful
4answers
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
9helpful
2answers
How to adjust the date in tagheuer watch
Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
14helpful
3answers
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
