This is what I found.
The date is usually set by pulling the crown out by a single click. You can then rotate it anticlockwise to change the date one day at a time. If your watch features a day display as well, this is usually changed by rotating the crown clockwise. To set the time you should pull the crown out fully.
SOURCE: Hugo Boss watch
go to this link and find your nearest Movado Group(they make and repair the watches) service centre; http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User4%20LIKE%20'_S%25' They can probably answer your question over the phone or e-mail, if not they certainly could if you could get the watch inspected. Most jewellers would also probably know - sometimes the serial number can be marked inside the watch, but I found no information online about your model that discusses this. Hope this helps, hope it's real :)
SOURCE: Cannot start new Hugo Boss Watch
check the battery, if it still wont work then try shaking it and see if there is something loss inside if there is, you bought the watch with already a technical problem
SORRY!!!
SOURCE: have lost back for Hugo boss gents watch is there
If you are in the UK try calling 01428 664700 - we are the official distributor for Boss Watches in the UK....
Testimonial: "Thanks for the help appreciate it."
SOURCE: how much will cost repairs of my hugo boss watches
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
