Fix your car right away by clicking the link I attached Nissan NP200
SOURCE: need torque settings for 1985 4A corolla cylinder head
hey, torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
SOURCE: need cylinder head bolts torque settings for nissan 3.2d
what nissan model do you need the head torques for
SOURCE: Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
SOURCE: golf iv 1.6 8v cylinder head torque settings
hi to tighten you have to do it in 4 stages as follows
1st stage 40nm leave 5 mins
2nd stage 60nm leave 5 mins
3rd stage 90 degrees leave 10 mins
4th stage 90 degrees
then you are done i will try put order on here i hope this works as follows
10 4 2 6 8
front of engine back of engine
7 5 1 3 9
in that order hope this helps
SOURCE: I need the torque settings
cylinder head bolts:
step one: 22 Ft-lbs.
step two: tighten additional 90 degrees
step three: tighten additional 90 degrees
