Refrigerator is to cold - I cannot locate where to set temp.
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
SOURCE: Freezer not cold enough; fridge OK
Hello cokoliso,
Welcome to Fixya
You said, your Trio won't make ice. Freezer stays at about 25 degrees regardless
of control setting. Fridge maintains 40 degrees at mid setting.
Shouldn't the freezer be close to zero? Is there a way to check the
temperature sensor in the freezer?
To check the temperature you can buy a refrigerator thermometer at the hardware store.
Ask if it can be used in the freezer too!
The fridge sounds slightly to cold and the freezer not enough.
Fist look in your freezer and check if the articles there are full to the max and covering the air vents usually found in the rear of the freezer.If so clear an opening for the freezer to breath.
Refrigerators and freezers usually share the cold air and I've seen this be the problem on many occasions.
If freezer was not I blocking the vents or even full to the max.
Then pull the plug out or if you can not reach the plug, trip the breaker off for 5 minutes and see if this resets the system.BUT do not plug the fridge back in before at least 3 minutes.
Let me know how it goes and send me any questions.
Thank You, Huuum
Please remember to leave a rating .
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working. Could be stuck or frozen or simply bad.
