Question about Green Cameras
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
Posted by Kenny on
NOEL
    Top Expert:
  • Green Master
  • 8,549 Answers
Hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Posted on Dec 01, 2017
5 Related Answers
Anonymous
  • 103 Answers
SOURCE: digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Posted on Dec 10, 2008
Anonymous
SOURCE: my casio camera battery does not charge
Simple solution  ! just wire a 9V battery postive to positive and negative to negative ( be careful not to interchange them ). hold it together for 30 seconds ! done !
All this does is give the battery diode inside, a boost ! so that its connectors are activated and Voila ! it works camera's now charging !
Posted on Feb 10, 2009
Rodie
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
Anonymous
  • 4 Answers
SOURCE: My rear flea light won't
it might be water damaged return it to bike shop and ask for full replacement under the lifetime warranty
Posted on Sep 28, 2011
Chris Morgan
SOURCE: The battery won't charge it
the makita lithium charger is red for charging, red and green for half way, green for charged and yellow if there is something wrong, you might be able to get them tested speak to the tool counter in a merchant of makita direct, as for the best solution comment they should have a 2000 life charge and mine are 3 years old and work fine and that's not moderate use really they are used most weeks and some weeks probably charged 3 times a week each
Posted on Apr 09, 2012
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Just got a new battery off Ebay..Installed in the camera and a red light came on..Does that mean that its charging or does a green light means that its charging?..Does the red light suppose to go off and...
Answered this one earlier-
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
My camara won;t turn on everytime i get a orange light then it turns off completly
charge the battery until light changes from red to green, then when you put the battery back into the camera make sure you push the battery all the way down until it locks in place. Hope this helps
Aug 16, 2009 | Polaroid T831 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Cameras Logo
Top Green Cameras Experts
NOEL
NOEL
Ngoro
Are you a Green Camera Expert? Answer questions, earn points and help others
