Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
Posted on Dec 02, 2017
SOURCE: kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Posted on Dec 09, 2008
SOURCE: kit. sprayer/hose
watch this http://www.pricepfister.com/about/diverter.aspx
Posted on Jul 02, 2009
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
SOURCE: sprayer weak working
http://www.us.kohler.com/onlinecatalog/pdf/1084452_2.pdf
Go to page 15 it has an exploded view of the faucet.
Posted on May 23, 2010
SOURCE: Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
Posted on Jun 28, 2012
