SOURCE: Benq screen resolution auto adjust seems to auto adjust wrongly
I would recommend you to bring it back and get a new one, if its till under warranty. You cannot fix the problem on the panel buttons it looks something to do with the components in the circuit bord.
SOURCE: I have a BenQ FP71G+ 17 lcd monitor
When you have strange problem like this, first place to look will be the power supply section. Look for burnt parts, leaking/bulging caps, that will be the starting point.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
SOURCE: I have a BenQ FP71G+ monitor and the auto adjust
radioactivet, A qualified technician will need to investigate the units "switch-mode-power-supply" for typical "faults" and locate the faulty (bad) component(s) that ma be causing monitor to act this way. "Noise" on the +5 volt DC rail going to the vga/lcd interface (processor) may be why display is acting "strange" with uncalled for pop-up's appearing!! That's the very first place I would investigate when dealing with ANY COLD-CATHODE-FLUORESCENT-LAMP, BACK-LIT LCD DISPLAY. 12fixlouie
SOURCE: stop auto adjusting of monitor/screen. the screen
Make sure your resolution is set to the native resolution of the monitor. In this case, 1280x1024
