Question about Sewing Machines
I don’t understand how to sew collar on in B 6107. I’m confused by whether I sew to facings and how I turn collar inside out
Posted by Joye Schwartz on
R.A. Ellis
  • Sewing Machines Master
  • 12,731 Answers
Take your collar pattern pieces & instructions to the local fabric store, like JoAnn's Fabrics, and ask if someone can help you.
Most often, you sew the collar pieces together (put right sides together). Sew the seams around the outside edges. Then turn it right side out, Press and then attach and sew to the garment pieces.
https://www.google.com/search?q=how+to+sew+a+collar&ie=utf-8&oe=utf-8&client=firefox-b-1
Posted on Dec 01, 2017
Jean DeLauche
  • 2,911 Answers
Hello, Joyce -
I hope I am correct in understanding you are referring to Butterick pattern 6107. If so, I don't own that particular pattern and accompanying instructions. Am I also safe to assume you do not have the sheet of written instructions with images to accompany the garment pattern? In case you have the pattern pieces but not the sheet of instructions, you may wish to contact the McCall Pattern Co. (Butterick is one of their brands) directly via email here: https://butterick.mccall.com/how-reach-us . Note: They may charge for replacement instructions.
In the meantime, assuming I am correct about your sewing Butterick pattern 6107, I see the coat has 2 collar styles - 1 a shawl collar and 1 a stand up collar.
If you are sewing the shawl collar version, perhaps this online tutorial (with pictures) on sewing a shawl collar will be instructive:
http://sewastraightline.com/2010/10/21/shawl-collar.html
If you are sewing the stand up collar version, this online tutorial (with pictures) may provide the right instruction: http://everythingsewing.blogspot.com/2013/03/adding-stand-up-collar.html
If neither of those resources seem helpful, then you may find an experienced sewer in your neighborhood who will offer to help show you what to do. How to go about that:
- If you are not already a member of the neighborhood web site Nextdoor.com, I recommend you join it (free.) You will be able to identify and limit your "neighborhood" when you register.
- Once you are a Nextdoor.com member, post a question asking if someone in your neighborhood could instruct you in how to sew the kind of collar you wish to sew. Note: I recommend using the private message feature to share addresses and phone numbers.
- There will probably be a kind neighbor or two who will be willing to come to your home and demonstrate to you one-on-one on how to sew the collar and turn it out.
If you would rather not follow the Nextdoor.com route, then, my last option is for you to contact the local public school system and ask for then name and contact information for the person / people who teach sewing (probably in middle school / junior high school) in the school system. Then contact a sewing teacher and ask her/him if you can arrange a lesson with her/him on how to sew your collar. I recommend offering to pay for the teacher's time.
Best wishes.
Testimonial: "Thanks! I actually think the directions in the pattern may be incorrect and looking at your link, figured it out. I am a pretty experienced sewer and was baffled. Thanks so much!"
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Dec 31, 2016 | Brother Sewing Machines
What is turning
Could be a couple of things.
If you are sewing a new collar, turning is done after you've sewn three edges together and then you turn the item so the right sides are out and the raw seams are enclosed inside the collar. Then the collar is attached to the garment using the fourth (unsewn) edge.
https://www.craftsy.com/blog/2013/12/sewing-perfect-collar-points
How to Sew Collar Points Melly Sews
Or turning on an old, worn garment is when the collar or cuff is unstitched from the shirt and then flipping it over so the worn part is on the underside and the fresh, clean part is facing up (as against the neck edge or, in the case of a cuff, against the arm). This is an idea from the depression era when people wanted to get more use out of an item that was showing wear.
Turn shirt collar
Oct 02, 2016 | Sewing Machines
Singer 306k Machine was working bery well then needle broke and I cant get the needle to line up with the bobbin case Tried reading manual 100 times Becoming frustrated Pls help
fit the needle correctly as too far up will tilt the needle when you tighten the collar up
there is a stop but it is not very noticeable
turn the machine over by hand (no thread) and see where the needle is hitting the bobbin case. the needle /hook timing may have altered
to check that the eye of the needle should be just below the hook as it reaches the needle
to adjust you will have to take it to a service center.
the needle goes in with the grooved side facing the thread and the cut away bit facing the hook of the bobbin
Sep 13, 2015 | Singer Sewing Machines
I need help with burda 7187
Usually with a wrap dress, you join front triangular pieces to bodice back at shoulders and side seams (often leaving a slit open in one side seam to pull the tie through). Then stay stitch neck and front edges to prevent stretching. Then neaten neck edges turn and stitch, or attach a facing. Probably if this pattern has a facing then you may need to attach skirt to waist and also attach the tie ends to the front edge before facing is attached. So when you turn facing to inside you will have the tie end in position at the point of the bodice/skirt seam on both sides of the dress.
Feb 28, 2015 | Sewing Machines
I have a delta sewing machine and cannot get it
Some of the older model sewing machines do require that the eye face toward the right. This would be the side of the needle that has the long groove for the thread to follow down the shaft and through the eye.
I cannot find a manual for a Delta sewing machine, so I would try the needle both directions.
Can you open the bobbin area (bottom spool) and watch to see if the needle and bobbin thread are connecting?
Apr 29, 2010 | Singer 7462 Mechanical Sewing Machine
I don't understand the instructions!!
You need to have a small white pencil looking object about 2 inches long this is like and extension for the unit take off the bobbin and put the pointed end in its place then but the larger thread on and replace the plug end.
LOL
Jan 11, 2009 | As Seen On TV Handy Stitch Mechanical...
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
