SanDisk Sansa m240 MP3 Player Logo
Posted on Nov 23, 2007
Playlist Problem !!!
When i bought my sansa m240 , I was able to make playlists on it but a few weeks ago everytime i try to make a playlist my songs doesnt appear in their playlist , but they all appear once with no playlists on !!!
please help cos i have lots of music and Qu'ran to put them in playlists , so i dont wish to have a song which is followed or precedes with some Qu'ran
  • ihatemath Feb 08, 2008
    i cant even make a playlist
  • Anonymous Feb 15, 2008
    I have never been able to create playlists on this MP3 player. When I try to do so, the individual songs are added, but nothing appears in the playlist menu on the device.
cemajor
Level 1:
  • Contributor 1 Answer
  • Posted on May 07, 2008
cemajor
Contributor
Level 1:
Answers
Questions
0
Helped
319
Points
The Sansa m200 series can only create playlists in MTP mode. on the menu go to settings>USB. There are two options MSC and autodetect. Once in autodetect your sansa should say MTP when connected to your PC. In this mode you should be able to add playlists without any trouble.
Hope it helps
How do I put music onto a sansa sandisk m240?
your mp3 should have come with a software cd. I had a sense mp3 and had to load program to my pc to add music.
1helpful
I can't get the songs downloaded from my Windows Media Center to the sansa m240 MP3
Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Sansa e270 playlist in rockbox
all tracks will be in their proper folder, but as far playlist (that is winamp playlist) rockbox will create a playlist unless you change it .....
here read 4.4 of rockbox http://download.rockbox.org/manual/rockbox-sansae200/rockbox-buildch4.html#x7-650004.4
1helpful
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
1helpful
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
1helpful
3answers
Rearrange songs on the SanDisk
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
3answers
Playlist
You have to create the playlist on your computer. Here is a tutorial on using Windows Media Player (version 10). http://mp3support.sandisk.com/wmp10/wmp10playlist.wmv Best of Luck.
2answers
How do you setup Playlists? - pls help
if you hold down the menue for like 15 secends it will ask to add to favorites you cant put in playlists I dont think. ~Grim
4helpful
2answers
How do i put a playlist on a sansa m240
#EXTM3U
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
