SOURCE: air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
SOURCE: lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
SOURCE: I need a manual for
Hi and welcome to FixYa, I am Kelly.
This should be your 8 page users manual:
http://www.appliancefactoryparts.com/content/pdfs/116668.pdf
If this answers your question would you at least say the problem is solved? Otherwise you will keep getting email notifications of where to find the manual.
Thanks for choosing FixYa,
Kelly
SOURCE: Can I get an owners manual for Hunter 30525 air
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
SOURCE: Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
Testimonial: "Thanks for the info. Anything I can do to fix it?"
