Televison & Video Logo
Question about Vizio Televison & Video
I have a Vizio D65U-D2 that will power on, and then after warm up, the display will go black, and audio will continue. I need advise on which part to replace to resolve that issue. Is it a known failure? Do you typically see success with replacing components for that issue?
Posted by Barrett Long on
Larry
  • Vizio Master
  • 4,631 Answers
Change the power board or look for bad capacitors, this is a common issue when filters are going bad..Good luck
Posted on Nov 30, 2017
  • Barrett Long
    Barrett Long Dec 03, 2017
    i replaced every board and the issue is still happening
  • Larry Dec 03, 2017
    Three possibilities..you received a bad board or its a cable or connector issue...or bad LED or CCFL
tuffbird72
    Habit-Forming:
    New Friend:
  • 44 Answers
Please review this video and see if this helps.
5 Related Answers
Anonymous
SOURCE: AVIC-D2 bad navigation?
what i did is, i went into the destination window and pressed the settings tab, then i pressed the hardware information after that i pressed the 3d calibration and then i cleared the section where it said hybrid 3d. after a while it worked fine.
Posted on Nov 08, 2008
Anonymous
SOURCE: Multiple Ignition coil failure w/ On-board computer failure
to beds_borders
That sounds very familiar. Our 2005 Ford Escape just had about the same problem to the tune of a $2800 repair. Computer failure caused two iginition coils to fail and had to drive over the Continenetal Divide on 4 cylinders. The vehicle is only 5 years old. Happened about 3 weeks ago. Ford said there is no recall. I have a big problem with that.. Where is the "quality" they are trying to sell?
Posted on Apr 05, 2010
Anonymous
SOURCE: replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
Posted on Apr 07, 2010
Anonymous
This is a common problem on most Ford products since around 1998. The issues is mostly with the COP--Coil-On-Plug. Their individual coils for eack spark plug,vs. a single coil pack or distibutor and wire type system. Now the good part. With all of fords problems, ALL MFG's use this type system,Nice move.
The coil driver failure, shouldn't be a wide spread issue
Forget recalls?
You saw Nissan ,recall issues,back to 2004 thru 2008,once Toyota had the gas peddle issues. If it wasn't for Toyota,they were laying low. Everyone new there were problems. Same thing on Chevy Colorado,Etc
Posted on May 09, 2010
Anonymous
  • 1622 Answers
SOURCE: Have a vizio 47" vo47lfhdtv10a,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout in solving the problem...
Posted on Jun 09, 2011
2answers
Model d65u-d2. Why does it have a black screen?
only an educated guess back light is the problem , might be power supply of the led strips call a local repair shop
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
Vizio model d65u-d2 NO POWER How to troubleshoot power on problems
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Open Questions:
Top Vizio Televison & Video Experts
Marvin
Marvin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
