Question about Vizio Televison & Video
My VIzio E550i-B2 TV has no picture and no sound. Do I need a new power supply board?
When you press the power on button the button lights for a few seconds and then fades away. No picture or sound comes on.
Posted by Clair J Krater on
Larry
  • Vizio Master
  • 2,800 Answers
What does the power indicator on the front of the set do when the on button is pushed?
Posted on Nov 29, 2017
Testimonial: "It lights for a second or two and then fades"
  • Angie Mobley
    Angie Mobley Apr 28, 2018
    fades off after about 5 or so seconds/
    have back panel off
3 Related Answers
Derrick Gee
  • 3 Answers
SOURCE: Vizio E550i-b2 TV has no backlight, pic or sound. Replaced power and Main boards - still having the problem. Any suggestions? I have the TCON and LED Driver board left
The led is what makes the picture try replacing that it it's the only one you didn't change out
Posted on Aug 31, 2016
gopakumarg43
  • 76376 Answers
SOURCE: Vizio e550i-b2
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Feb 16, 2017
shaun taylor
  • 1527 Answers
SOURCE: ordered Vizio 056.04167.0001 Power Supply / LED Driver for E550I-B2 the sound worked before switching it out, but picture did not. Installed part & picture only stayed on for a few minutes & no sound.
hi the led in the panel may have shorted out thanks
shaun
Posted on Mar 27, 2017
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
Televison & Video Logo
342 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
