Device is a Blu life one x2. Your software update pushed out on 11/28/17 has locked my phone. Asking for a password. Tried my 4 digit pin, and my Blu account password, and many others. Nothing worked. 8 tries left to device wipe, so the screen says. HOW DO I UNLOCK THIS PHONE??????
Please, why would you trust a bunch of WWW strangers who might use up up all your eight tries, before asking for help from the software provider?
Either way, what software? What's Your software update, please? Not from here, nor anywhere like here, it didn't.
Most obviously, a software update on your phone might have come from the phone factory, or your service provider and after them from the supplier of any app installed on your phone.
Exactly what update are you asking about, please?
SOURCE: forgot my 8 digit password phone lock code. Is
The only way to get into a phone that you've lost the password to is to completely reset it, wiping out all of the data on it in the process.
You can check with your provider and see if they might have a built in solution for forgotten passwords, but typically you'll need to wipe out the phone and start over.
SOURCE: Garmin Nuvi 310 D
You can lift of the grey trim on the front and then hold down the reset button might not work though but its worth a try.
SOURCE: software update on Env2
One of the biggest problems with this phone is the OK button not working, and the front keypad doing the same eventually. Everyone I know with this phone has the EXACT same problem.
SOURCE: i have locked my friend
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion
1. Power off phone.
2. Hold camera button and power on phone at the same time.
3. Release the camera button when prompted to.
4. You will see a message screen telling you to press the up or down volume button
5. Press the down volume key (ignore message 'Volume Up Key Pressed') - This is fixed after updating to 2.1 and the proper message shows
6. When triangle and phone screen appears
7. Press on the screen just above the back key
8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back]
2. apply ssdcard:update.zip [Alt+S]
3. wipedata/factory reset [Alt+W]
You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and
the screen changes to a box and a phone (Get it - out of the box) and
you see what is happening on the phone.
pick 2
-- Wiping data...
Formatting DATA:...
Formatting CACHE:...
Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restarted and took me through the setup prompts.
