How i solve kernel panic upload mode on galaxy S5300
SOURCE: user fault kernel panic upload mode
try this & good luck :)
turn off your phone with hold the power button-----take battery out-----turn on again with press the power+volume up button, hold until samsung logo appear then release the button-----type *#9900# on call menu-----select "choose debug level" then switch to normal.
SOURCE: user fault not kernel panic upload mode
From the Samsung GT-S5300 user manual -
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close applications or reset the device to regain functionality. If your device is still responsive and an application is frozen, close the application with the task manager. If your device is frozen and unresponsive, press and hold the Power key for 8-10 seconds. If this problem persists, perform a factory data reset. In the application list, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
See Troubleshooting section (pg 109) -
http://bit.ly/1Pqin8c
