Should check the manual: http://office.manualsonline.com/manuals/mfg/fargo_electronics/hdp5000_1.html?p=141
Testimonial: "I already tried with default password and it isn't"
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
SOURCE: Cannot change network settings - Admin password unknown
Got in with random trialling passwords for the Administrator... finally found the default password for Administrator on the Sharp MX2300N was "admin". Should have known...
Got in, set up the IP's and away we go again. Did not have to go in with any maintenance mode or re-setting the whole system.
SOURCE: DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
SOURCE: Is there any other way to reset the default
If you isp is Consoidated Communication
username admin
password cciadmin
