What is the model number?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong.. Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
SOURCE: My visonpro Honeywell 8000 digital
Push the System button, then in the bottom row of empty buttons, press the middle buttton for 4 seconds. The display will change, showing system codes on left and that code's setting on the right.
Choose 670, and option 0 opens it up completely, option 1 locks it partially. You should not try to override settings the HVAC/Building admin has set for you, in case you are trying to defeat their control.
SOURCE: Unlock a Honeywell Thermostat
here is the link to get a manual for your particular theremostat.
http://yourhome.honeywell.com/yourhome/CMSTemplates/SolutionByCategory.aspx?NRMODE=Published&NRNODEGUID=%7bBE070174-CDA8-4628-8D04-7598F09C71E1%7d&NRORIGINALURL=%2fConsumer%2fCultures%2fen-US%2fProducts%2fThermostats%2fDo-It-Yourself%2fProgrammable%2fDefault%2ehtm&NRCACHEHINT=Guest
SOURCE: How to lock a Honeywell TB7220U Thermostat
With directions go to system. Then hold down 2 blanks on either side of middle for 30seconds this shows you Advanced settings . Read through and find the proper settings
SOURCE: Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
honeywell cm921 problem with red light flashing tenp not controling boiler can any one hel
You will have to contact Honeywell to see what the procedure is to unlock a tstat when the pin is lost. If you still have the book their customer service number should be in the book if not you can get their # on line
