I have a DCU72 which had a chipped tube (TG007) which seems discontinued.
I purchased a TG039 from www.thegourmetdepotco.com, and this seems a usable replacement.
The only caveats are that the tube is slightly shorter (7 inches) than the previous one,
so I cannot fill the pot to the 60 cup capacity (keep at about 50-55 cups or less).
The other option I did not try is to just not have a coffee level tube, and block the hold in the spigot
with a plastic disk the same diameter as the original tube.
SOURCE: looking for glass tube for delonghi 60 cup coffee
Here is a number you can try, to obtain a replacement part:
Contact Center
1-877-882-8604
Monday – Friday
8am – 8pm EST
Hope this helps... Good luck!
SOURCE: have a 60 cup delonghi coffee maker which lights,
Sorry to read about your problem, I hope this helps you out.
sorry, but it sounds like you have a defective heat element.
you can contact Delonghi 1-800-322-3848
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
SOURCE: How much coffee to add
I like my coffee pretty strong and I use 2/3 cup coffee to 10 cups of water...
You may be able to use 1/2 cup to 10 cups if you don't want it too strong...
You must experiment a bit as different coffees will vary also...
heatman101
