Press the TV button on the remote. It toggles between analogue and digital.
Have you done a channel scan? This can take a few minutes but it locates and lists all channels If you've not done this already, go into your menu, channels and be sure to enter the receiving input whether it's antenna,cable, or satellite, start your scan and see what channels you're receiving. I sure hope this helps and good luck
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
SOURCE: how to connect nintendo 64 to panasonic viera tv
it depends what connector cable you have if you have an AV cable hook it into the red white and yellow colored inputs if you have an RS cable for the 64 screw this into the back of the tv where the antenna input is.
SOURCE: Can the Panasonic DMR-EH55 be made to receive
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
SOURCE: Windows 7 media centre is
You need to connect the tv on the network, press the green button on the remote, follow the instructions and the code will appear on the screen. But only few models of selected countries of these tv's have the Media Center Extender capability - if the tv that you bought doesn't have the Green button then you can't pair it up with your pc. In that case you will have to connect it to a router and configure it just like another pc - not directly to your pc.
