Question about Home
Troubleshoot for my new england clock mantel,wind-up pendelum clock?
My new england clock co. mantel/wind-up/pedellum clock stopped running and I can't get it going again using the instructions online! please help!
Posted by Otis White on
Don Eagan
    Master:
  • 714 Answers
Your spring may have been overwound. There are several YouTube videos that show you how to release an over-tightened main spring.
Posted on Nov 28, 2017
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: The clock runs fast , 20 plus minutes a day... Is
mcdevito75 here, There should be a F/S on the back of the clock, if so place it in the middle, if not, check out a small watcg repair shop in your area.
Posted on Jun 27, 2010
Azrael SRL
  • 11800 Answers
SOURCE: i have the wall clock
The clock must be perfectly level - check that with a spirit level. If you don't have one then a wire with a weight attached should do.
When you swing the pendulum for the first time try to swing it at it's normal movement angle, if it's too high or too low the mechanism will not be able to sync with the quartz and the clock will not work.
Posted on Oct 04, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have an early 1900
You can not unwind the clock yourself, because this requires proper clock makers tools and skills as well. Clock is stopping because it has not been serviced for a long time and the oil in clock has collected dust particles and getting sticky. This does not let the spring unwind freely and is a problem for all cogs and moving parts. Find your nearest clock repair shgop and ask for cleaning, oiling and adjusting. BE AWARE: If you are gonna try to unwind it yourself, you will damage the clock's movement, but most important - you can even brake or loose your fingers, as the clock spring is under unbelievable tension and once released, it uncoils lightning fast and is sharp as a razor.
Posted on Oct 28, 2010
David Tolond
  • 2501 Answers
SOURCE: How do you control how
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Posted on Feb 11, 2011
After spot cleaning mantle clock with German movement (circa 1960), the clock chimes properly on the hour but does not chime on the half hour.
I am hoping that you oiled it also? One trick I have found is to gently lift the hammers and release, sometimes the hammers will release and strike the chimes/gong. Do this 4-5 times and hopefully it will get it chiming for you again.
UsedClockParts.com
Nov 09, 2016 | Home
I have a Linden mantel clock with chimes and 3 winding squares. Which square is for which function? I cannot seem to find this info anywhere!
I believe the one on the right is for the chimes, the one in the center is for the time and the one on the left is for the gong (on the hour).
Main Page
Nov 01, 2016 | Home
Setting tochigi tokei co quartz westminister chime
the 2 hour buttons and 2 minute buttons represent a 24 hour clock ie 2:55 is 1452 hours so press first hour button onces the second hour button 4 times then the first minute button 5 times then the second minute button 2 times
Nov 25, 2012 | Seiko Mantel Clock
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
Feb 10, 2011 | Watches
Chimes do not chime due to winding too tight. Can this be corrected?
You need to remove the movement and use a tool to manually unwind the chime spring. This can be dangerous and can break you wrist, so you might consider having a clock repairman perform this maneuver. Then wind the spring about 1/2 way. If the chimes still do not operate, I suggest a good clock repairman.
Fred
Apr 20, 2010 | Seiko Mantel Clock
Pendelum is free but will not rotate. Clock keeps time OK.
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to get gold for wow with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 07, 2010 | Seiko Mantel Clock
Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Home Logo
93 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
