SOURCE: no pressure from pressure washer
Do you plan on doing the repair yourself. I need more info, when you supply water to the pressure washer, pull the trigger to purge air from pump, and start the machine. Do you see water coming out from the bottom of the pump? Do you hear the pump working or is it quiet. If you hear a cycling pattern or hear the pump trying to push the water out but it isn't, then you may have a blockage inside the trigger or the spray tip. If the pump isnt building pressure then you may have a pump problem. A stuck check valve, cracked plunger, bad seal, or could be air bound.
SOURCE: honda gx270 pressure washer. water is not coming out strong.
did you check the inline screen for dirt?
SOURCE: I have a Husky pressure washer with a Honda
check the quick disconnect to the wand these are spring operated and can get stuck
SOURCE: pressure washer not working
OK here is the solution. There are six plastic vaules inside the pump if you have any mechanical skills you can fix this.
These plastic valves melt when you leave your pressure washer running for a short period when you are not pressure washing. once this happens the pump becomes cloged and does not function. I spent alot of time and research on finding the parts for replacement. I called the main company of this washer pump and here is the toll free number
800-999-2245 and the web sight www.pressureparts.com but to save time just call and talk to the service tech tell him you model number and he will give you the part number.
I only paid $13.75 plus shipping around $5.50 I do not work or have any intrest in this comapny but I tell you after all the frustration and run around I had trying to fix this Home depot power washer I deesided to help eveyone else out
I can be reached at [email protected] if you have any other questions
SOURCE: Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
