Question about Alphasonik Car Audio & Video
What color light is post to be on for a alphasonik app for the power and what color light is for protection mode
Posted by Jason Cotter on
1 Related Answer
fingaz22
michael schultz
  • 1068 Answers
SOURCE: I have an alphasonik pma600hca everytime i power
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Posted on Jan 31, 2010
Is the red light that says protection on the hifonics hifi1001.1d suppose to be on or of? My is not on is that bad
My guess is if there is a fault and it has to go into protect mode the light will come on. The red color is usually stop or warning etc ... green = go or good.
Dec 01, 2013 | Car Audio & Video
I have an alphasonik pma600hca everytime i power it up it goes into protect rite away???? Any ideas???
Jan 21, 2010 | Alphasonik PMA600HCA Car Audio Amplifier
How to fix protection light
It's usually your ground. Make sure it's secured to something metal. If it's a painted metal, sand a spot down to the paint for the contact. It could also be a screwed up speaker or even interference between wires. Make sure they're separated and insulated.
Jan 04, 2010 | Alphasonik PMA1000HCA Car Audio Amplifier
My sansa fuze wont play i know it has power in it because the blue light surrounding the center dial is lit yet i cant get a screen to come up nor can i shut it off
Sandisk gives next support link, how to recover the player:
http://kb.sandisk.com/app/answers/detail/a_id/4/kw/blue%20ring/r_id/101834
Solution 1: RESET THE DEVICE
Scroll to the Sansa Fuze on next site, how to perform a reset:
http://kb.sandisk.com/app/answers/detail/a_id/188/kw/blue%20ring/r_id/101834
When solution 1 did not help.
Solution 2: RELOAD AND UPDATE THE LATEST FIRMWARE
All data on the player will be erased when updating firmware !
Go to next sites, seeing how to do a firmware update:
1. To perform a firmware update the player has to be in MSC mode.
How to put the player in MSC mode, see the information about the
Fuze player:
http://kb.sandisk.com/app/answers/detail/a_id/61/kw/blue%20ring/r_id/101834
Putting Sansa Fuze in MSC mode:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the left button ( |<< ) while connecting the device to the PC.
2. Continuing with the firmware reinstallation you can choose either automatic or manual update, see:
http://kb.sandisk.com/app/answers/detail/a_id/278/kw/blue%20ring/r_id/101834
Automatic update using the Sansa Updater.
or
Manual update going to Sansa Forums.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa Fuze MP3 Player
3 caps inside exploded powere light just flashes
WELL MY FRIEND THAT NEED TO BE BENCH TESTED YOU HAVE SHORT CIRCUITED THE AMP
Jul 14, 2009 | Alphasonik PMA1200D Car Audio Amplifier
Alphasonik amp is getting power but no power to subs
either your rca inputs are bad or your mosfets are bad
Jul 05, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Unit is in protection mode
Disconnect all speakers from it, then turn it back on. If the unit is OK, it should come out of protection. Turn it off, then reconnect one speaker and power on, repeat until it goes into protection, then you know where the problem is. Now disconnect the speaker wire that caused the problem but this time at the speaker. Make sure your wires do not touch, then turn it back on. If it stays on, it's a speaker problem, if it shuts off it's a wire problem. If you still need more help, post a comment and I will help some more. Hope this helps
Jun 14, 2009 | Pioneer M10X 2-Channel Amplifier
Protection Light
when the protection light comes on means either you have something like you power and bround backwords,or you have speaker wires touching somewhere..
Dec 04, 2008 | Alphasonik PMA1200D Car Audio Amplifier
Red status Light
If the protection LED is lit, the amp is in protect mode and probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Trubleshooting
Let me know if you have any other questions.
Nov 07, 2008 | Boss AUDIO RIP-596 2-Channel Ripper Series...
Car Audio & Video Logo
50 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
