Home Logo
P
Patricia Silva Posted on Nov 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water keeps filling in toliet even after full
Fluidmaster 300 valve in tank water keeps running after is filled up also water comes out of top of the valve
NOEL
Level 3:
Top Expert:
  • Master 8,606 Answers
  • Posted on Nov 27, 2017
NOEL
Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2320264
Points
68630
Hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
5 Related Answers
Anonymous
  • 43501 Answers
  • Posted on Jul 28, 2010
SOURCE: After each flush, the tank fills but the fill
Usually the problem is dirt in the fill valve and not an adjustment problem...
depending on which valve you have it can be taken apart and cleaned out... just remember to turn off the water supply before taking the fill valve apart...
Anonymous
  • 100 Answers
  • Posted on Dec 03, 2010
SOURCE: the top tank of my
Your Fill Valve needs to be replaced. The life of the Fill Valve can be shortened by the hardness of water or by using tabs to keep the bowl clean. If it is a one piece toilet, use the Korky adjustable Fill Valve. If it's a two piece, use the Fluidmaster 400A. If you attempt this make sure you turn off the water supply valve and flush all the water out of the tank. When you go to tighten the plastic screw, be very gentle and don't overtighten because the tank WILL crack otherwise. Hope this helps!
Anonymous
  • 1015 Answers
  • Posted on Jan 29, 2011
SOURCE: i have a fluidmaster 400
If your fluidmaster is an older model then the top comes off by pushing down on it lightly and turning it about 90 degrees. Of course you want the water off when you do this. When you get the top loose you can remove rod that connects to float and then you will see a round flat rubber seal. This seal is probably what is causing your problem. On newer model they have two clips ,one on either side of valve cap that need to be unlatched to access the seal.Good luck. Thank you.
joemidjette
Joseph Midjette Sr.
  • 158 Answers
  • Posted on Mar 11, 2011
SOURCE: I have a fill valve
There should be a small flexible tube/hose that came with this and goes over where the water is spraying out, it should look like a little nipple, the hose goes on there and then to the white tube appoximately an inch or so in diameter that goes to the bottom of the tank where the flapper ball is connected. The small flexible tube is supposed to connect to the top of the larger tube via a clip so-as to fill the toilet bowl back with water. If everything is connected like it's supposed to be then you might have a cracked fluidmaster.
Anonymous
  • 16 Answers
  • Posted on May 19, 2011
SOURCE: fluidmaster toilet fill runs when
If there is nothing wrong with the fluidmaster, it probably needs to be adjusted, sounds like it is running down thru the overflow tube!
8helpful
2answers
My fluidmaster 400 anti siphon for toilet will not stop filling making pump run over and over
Hi turtlerose07...
Sounds like you have one or two problems with the fluidmaster 400.
1...The float is set too high allowing the water to overflow into the overflow pipe and allowing your pump to run too much.
2...Flapper valve inside at the bottom of the tank is not sealing properly, thus allowing water to leak and causing the fluidmaster to keep trying to fill the tank with water and causing the pump to run too much.
Please take time to rate me
Aug 24, 2011 • Home
Hi there we have a caroma slimline toliet 2000+ that hisses constantly after you've flushed and the system fills up with water.even when its full it still hisses we have replaced the ballcock and the...
this is usually caused by slightly higher than normal water pressure in your area or foreign matter lodged in the fill valve body. the quickest/cheapest solution is to flush the toilet and turn down the pressure to the toilet by slowly turning the shut off valve toward the off position till it stops making noise. otherwise you could replace the fill valve w/a "whisper" valve by fluidmaster, from home depot,lowes,etc, which is much less noisy in general but even a whisper will make noise if the water pressure is to high. hope this helps but if you need anything else just ask:)
Jul 31, 2011 • Home
1helpful
I have a fill valve that says Fluidmaster 747. when tank goes to fill it sprays water out at the top
The tank is filling very slowly. The little hose coming from the side of the unit is plugged, no water is flowing thru it during tank filling.
Fluid master comes apart at top.Turn counter clockwise to unsnap .You will see water valve seal. take seal out and clean out any grit. reasemble and should work. hope this helps.
The top tank of my toliet wont stop filling. water is coming out of the flush lever??? I had to turn the water off to it
Nov 26, 2010 • Home
3helpful
After tank fills up, water continues to flow a little. How do you fix it?
Replace the top cap of your fill valve, or just the fluidmaster seal disc. Here is a link to the Fluidmaster fill-valve Instructions.
3helpful
My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
2answers
Water continues to flow after tank fills
you need to replae the float valve
go to Ace hardware and get a fluidmaster fill valve kit
they range from $7 to $9
come back
turn water off at riser( up to the tank
flush toilet remove tank top lift the flapper up and lt water drain
get bucket or small bowl
remove the plastic nut that holds the silver risr or flex line
look up under the tank there is a large lock nut screwed onto the plastic fill tank assembly
remove the nut (try to place bowl to collect wter left in tank
remove the float assembly from inside the tank
Install new fluidmaster ( flow step by step directions
good luck
Jan 05, 2009 • Home
5helpful
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
