Question about Watches
I have a digital wrist watch and I can not set it up.
Posted by Claude Chepil on
NOEL
    Top Expert:
  • Watches Master
  • 8,546 Answers
Hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Posted on Nov 27, 2017
5 Related Answers
Anonymous
SOURCE: Tissot wrist watch goingin reverse since new battery fitted
It sounds like the battery might be in backwards. They do
have polarity,...it DOES matter how it goes in. Try opening it, and
flip the battery to see if that helps.
Mark
Posted on Mar 06, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 31, 2009
Anonymous
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
Anonymous
  • 10 Answers
SOURCE: How can i set digital time and alarm in the Timex
Try this ,it may work for you as i m having mf13-t1
Press MODE then then SET
Press ALARM to increase the count and to change time t1 or t2.
Press MODE to switch the digit place
finally press SET and then MODE
Note: Check for bell and sound symbols,if they are not there
Press MODE then then SET again press SET
Press ALARM for once or twice depending on symbols.
Posted on Feb 19, 2010
Anonymous
SOURCE: setting time and date
need the right time on my computer, need a time change
Posted on Jun 22, 2010
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
H0w do i set the time on this watch
With One button without Head you can set the Analog Watch.You must push and wait.
with the Mode you can set the digital display watch or with adjust button push it for 2 sec and when the digital display seconds play every seconds you can edit the Time.
Watchmaker Video Review For Watchmakers and Watch Fans
Nov 05, 2014 | Casio Waveceptor WVA104HA-1AV Wrist Watch
Cannot set the digital time
Read the instructions it came with or look for an interactive video online. That is going to be the easiest way.
Dec 26, 2013 | Bulova Watch
Bought watch (T5K160) with no instruction pamphlet. Can you help me set it please?
press and hold the set button. when digits blinks it is the start of setting the time, date etc... "mode button " is for choosing what will you set. the blinking digit is the one to be set. after you have set all. press the "set" button to finish.
Jul 12, 2011 | Timex IRONMAN Triathlon 50-Lap Mid T5K160...
Change time
Welcome to Fixya,
If you need instruction on how you can set/ changed the time on your Citizen Eco-Drive Calibre 8700 Wrist Watch, you can try this link.
http://www.citizenwatch.com/COA/English/settings.asp
I would be more happy to assist you if I know your 4 digit Movement Caliber. You can found it at the back of your watch.
Hope this link will help you and can answered your question.
Thank you for using Fixya.
Feb 23, 2011 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How do you set the analog and digital time on the casio aw-s90 wrist watch?
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 03, 2010 | Casio AWS90-9AV Wrist Watch
I bought a CASIO Telememo 30 2747 AW-80M wrist watch yesterday in Chennai, India. No manual was sold alongwith the watch. I want to know the features of the watch and a soft copy of instructions...
Hi, Try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you.  Thanks, Bill
Sep 07, 2010 | Casio AW80-7AV Wrist Watch
I cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Mar 30, 2009 | Casio WVA430A-1AV Wrist Watch
Battery removal?????
How do I set the watch hands, I can set the digital part, but I can not seem to change the "Hand" Settings.
Jan 26, 2008 | Casio AW80-7AV Wrist Watch
Casio WS300B-1BV Wrist Watch
Punch in the 4 digit module number found on the back of the case.
Jan 18, 2008 | Casio WS300B-1BV Wrist Watch
Watches Logo
305 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
