Lasser printer cant scan then display 255 error
SOURCE: canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
SOURCE: service error 5200 for my printer Canon S200SPxhow
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Hope this helps. Please rate my response.
Thanks.
Have a good day.
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
SOURCE: i face error code 2,114,0 error in canon printer
Is it a refill or compatible cartridge? If so then the printer will not read full ink levels only with genuine Canon ink.
The printer will work with refills/compatibles but you need to press the reset button (this should be a small round button which has a red triangle in a circle on it) hold it down for a fair few seconds and that will get the printer working. You just ignore the message of low ink.
If they are genuine inks then it may be the connectors need a gentle wipe with cartridge flush as there may be something on them that's not allowing them to make the correct connection with the printer.
If they still won't work you need to take them back to where you bought them and ask for replacements as the ones you were given are faulty.
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
