Question about Bulova Watches
The date window on my Bulova Accutron 518 just started flashing; is it trying to tell me something?
Posted by Ed Quigley on
5 Related Answers
Anonymous
SOURCE: Opening Bulova Casement
Take it to a local jewelery store and they will do it for about $15. Joe
Posted on Oct 03, 2007
Anonymous
  • 206 Answers
SOURCE: Day, date and time for a Bulova TFX watch
Step 1. When the second hand re a ches 12 o ’ clock (the zero or 60th second mark ) , pull the crown all the way to the “OUT ”position (you will hear two “ cl i ck s ” ) .All hands will stop.
Step 2. Turn the crown to move hands FORWARD (clockwise) until you see the date (for date only) or both day and date change.This establishes midnight, t h e b e ginning of the day.
Step 3. For A.M .time, continue to move hands forward until the minute hand is approxim a t e ly 5 minutes beyond the desired minute marker ;then ,gently turn b a ck to the same marke r. For P. M .time , follow the same procedure ,but first a dvance  the hands past 12 o’clock .
N O T E : The date will advance automatically at midnight, p rovided that A . M .a n d P. M .h ave been established (Steps 2 and 3).The watch calendar is pro grammed for a 31-day cycle.The  refore ,on the fi rst day of any month fo l l owing a month with fewer than 31 day s , the date must be advanced manually (see Step 5).
Step 4. When the time standard by which you are setting your wa t ch ( e.g.,telephone beep) re a ches the 60th second, push the crown all the way to the “ I N ”position . All hands will start instantly.
Step 5. Pull the crown to the “ I N T E R M E D I AT E ”position (one “ cl i ck ” ) . Your watch will continue to tell time. S l ow ly turn crown one way until the correct date a p p e a rs .Then for day/date models, s l ow ly turn crown the other way until the correct day appears .
N O T E : The day is printed in two successive positions on the day indicator: i n English and in Spanish on U. S .m o d e l s ; in English and in Fre n ch on Canadian mode l s It is possible to make use of either position. The display will automatically re m a i n in the language ch o s e n .
The date should never be ch a n ged manu a l ly between 9:00 P. M . and 3:00 A . M .a s this might affect the calendar mechanism and the accuracy of the date. ( Theme chanism will not be damaged if the crown is turned accidentally during this
time peri o d ,howeve r. )
Hope it helped U!
Posted on Jul 30, 2009
Anonymous
SOURCE: i have a bulova accutron with a 14KT gold case.
Since the serial number (E66289) begins with a letter, the watch was made in the United States. (Serials that begin with a number indicate the watch was made in Switzerland.) Look at the back again and see if there's a two-character code, such as M2. Compare the code against the list on the following link to find the year of manufacture: http://www.thewatchguy.com/pages/BulovaSerial.html
If it's an Accutron, visit this site to see if it's a 214. He's got a wealth of info on 214s! Good luck!
Posted on Jan 26, 2010
David Tolond
  • 2501 Answers
SOURCE: I have a Bulova Accotron (M7) Is it automatic
If you go to http://www.bulova.com/service/servicecenter.aspx, you will be able to locate the nearest service center, who will be able to advise you. (incidentally, after such a long time idle, it may need servicing).
Posted on Apr 08, 2010
Anonymous
  • 3 Answers
SOURCE: Bulova accutron 2 years old stopped running after
Try giving the watch a sharp tap with your finger at the 3 or 9 position on the bezel. As Accutrons age the permanent magnets lose a little strength and sometimes need a "jump start" to get the tuning fork vibrating. If that works, it will run until the battery is replaced again. Good luck
Posted on Jul 19, 2010
I have a mans accutron bulova watch serial number H 963884 look for info year value
Value information here
https://www.google.ca/search?rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&q=bulova+accutron+serial+numbers&sa=X&sqi=2&ved=0ahUKEwjM14mTz7PQAhUT4mMKHb7LB3YQ1QIIZCgB
Determining the Date of a Bulova Watch For purposes of assigning a date, Bulova watches break down nicely into three basic groups: 1) pre-1926, 2) 1926 through 1949, and 3) 1950 and beyond. Those three date ranges are differentiated by the presence or absence of certain case and movement markings as well as the nature of any such markings, as explained below.
In general, for all time periods, it is important to understand that Bulova watches never provide an obvious date of manufacture anywhere on the watch. Rather, the date must be "de-coded" using symbols, serial numbers, and two-character codes placed on various parts of the watch. These codes and the manner in which they should be interpreted is the subject of this article.
Many observers of Bulova watches are confused by the sometimes seen patent dates stamped on the inside of some Bulova watch cases, and they misinterpret such dates as the time of manufacture. In point of fact, those patent dates apply only to certain aspects of the case design and indicate only when those general designs were patented. Those designs were used on many watches produced over a number of years, and the applicable patent date in no way indicates when any particular watch was produced. Below are images showing the two patent dates that often cause confusion.
Read LOTS more HERE: http://www.watchophilia.com/general-information/determining-the-date-of-a-watch/
accutron bulova Google Search
Nov 19, 2016 | Bulova Watches
My uncle gave me a bulova watch and i want to know how old it is? the back reads 1765771 bulova 10k filled.
Is there an "A" on the back with a number next to it ? This is the date code, A1, A2, A3, etc. = 2001, 2002, 2003 and you know the rest.
Nov 30, 2010 | Accutron Swiss Watch by Bulova 26B44
How do I tell what model Accutron I own? I obtained it as a graduation present in 1972. The serial number is H233723.
The only people who are likely to be able to answer your question is accutron (assuming that they keep records that far back- which they might).
Go to http://www.bulova.com/brands/accutron/accutron.aspx?brand=accutron and scroll down to the bottom of the screen and click on "contact us"
Oct 31, 2010 | Accutron Extra Value 26R05 Watch
Need complete instructions to set my 26B29
Took me a while, but I found the answer at the following link:
(Who knows, maybe I'll need it again next time I change my battery)
http://www.bulovaspecialmarkets.com/BulovaDynamicRepository/instructions/518.pdf
Sep 02, 2010 | Accutron Breckenridge Chrono 26B29 Wrist...
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
Aug 15, 2010 | Bulova Wrist Accutron Lucerne White M. Of...
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
RUNNING FAST
Accutron is made by Bulova. Follow this link and click on Accutron: http://www.bulova.com/index.aspx At the bottom of page click on CONTACT US. Rate me, please.
Feb 26, 2010 | Accutron Watches
How to quick set date on n5 accuquarz bulova watch [this watch has date only]
Hi friend i am providing a link I hope this will help you out.
http://reviews.ebay.com/How-to-set-day-date-on-Bulova-Accutron-2182-movement_W0QQugidZ10000000006982861
Gud luck.
Oct 06, 2009 | Watches
Flashing numbers in squares
Flashing Squares means battery going dead - time to replace. May take up to 3 months to stop.
Aug 25, 2006 | Accutron Breckenridge Chrono 26B29 Wrist...
Watches Logo
54 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
