Hi Sonnyfresh, Follow the following steps:
Step 1 - Open the Case
Use a small screwdriver to open the case. Be careful with the contents inside after the case is open, as you do not want the tape and the system to fall out of the case and unwind. To prevent this, keep your finger on top or use a small piece of masking tape to keep everything in place.
Step 2 - Look Inside
Take a look inside the case to see if there is a simple problem with the retraction system. For example, the spring might be undamaged but unhinged from the tape, or there might be dirt clogging the spring.It's an easy fix, remove the dirt or reinsert the spring, and then proceed to the sixth step to close the case.
Step 3 - Remove the Tape
If the problem runs deeper than a bit of debris, you will have to remove the tape to observe the retraction system. Take the tape slowly out of the case, holding the retraction system in place. Once the tape is completely out, disconnect it from the spring.
Step 4 - Replace or Fix the Retraction System
If the spring is broken, or damaged, you will need to replace it with a new one. You should be able to replace it. Make sure you have the model number and size when you go to the purchase one.
Step 5 - Put the Tape Back
After replacing the spring, connect the tape to the spring by putting the end of the spring into the hole at the start of the tape. There is usually a part connected with tape. Use some masking tape to put it back together. After you've secured the connection, let the tape roll slowly back into the case.
Step 6 - Close the Case
Test the retraction system by letting the tape roll in, hopefully you have repaired retraction system. Remove the masking tape keeping the system inside the case, and reattach the top cover with the screwdriver. Your tape should retract again properly.
Kind regards
Davoid
SOURCE: Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
SOURCE: DSR 11 playback problem
Pete, we are having the same problem with 2 dsr-11s.
The fix for us was the "auto repeat" switch on the back of the unit. It was "on" please turn it off.
The other idea was that the tape tension is very sensitive in the units, try exercising the tape (though exorcise might be good too) by fast-forwarding then rewind the tape start to finish. Tape that were tightly wound at the factory can cause this proble as well. Good Luck. Greg VA
SOURCE: Right-side cover will not close, springs are disconnected.
Normally the right cover hooks break off and causes the door not to close.There is square holes in front and back of the right cover that you can use to hook the spings again.
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
