Question about Home Fencing
Have turned off switch & left off for a few hours. Turned back on, but nothing.
SOURCE: wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Posted on Aug 15, 2008
SOURCE: '03 SLK 230 top wont close - stuck half way open
first thing I would try, disconnect the battery to the car for a minute, then reconnect it. that may correct your problem.
Posted on Aug 30, 2009
Testimonial: "Thank you so much! That was the fix no one (else) could give me on a Sunday. Now I need the code to unlock the stereo... I will check with Mercedes."
SOURCE: The sunroof is tilted open and won't close. When
Sounds like sunroof is stuck, motor can't overcome load. Cheap test: car off, interior light turned on try to move sunroof, does light dim? If yes motor is trying to move but can't. If light does not dim then motor not getting power.
Posted on Mar 09, 2010
SOURCE: My 2009 Toyota Highlander lift
Thanks for choosing FixYa and welcome to the site. You need to make sure that your fuse is not blown. Check your fuse box diagram for the location. If the fuse is fine, you may have a bad switch. There could be a loose wire or a bad connection to the switch.
Posted on Apr 20, 2011
SOURCE: right power sliding door wont open or close on my
door motor is worn out or track needs lubed or cleaned. sometimes grit gets in there and jams the tracks.
Posted on Sep 25, 2011
May 02, 2018 | Cars & Trucks
Feb 13, 2017 | 2006 Lincoln Navigator 4x4
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
Power Liftgate Module Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1342
ECU Is Defective
INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section.
B2477
Module Configuration Failure
REFER to Section 418-01.
B2522
Vbatt1 Circuit Failure
GO to Pinpoint Test B.
B2552
Vbatt2 Circuit Open
B2698
Vbatt2 Circuit Failure
B2699
Left Pinch Strip Open Or Short To Battery
B2700
Right Pinch Strip Open Or Short To Battery
B2701
Left Pinch Strip Stuck Active
B2702
Right Pinch Strip Stuck Active
B2703
Open/Close Switch Stuck Active
B2704
Optical Sensor Power Short To Ground
B2705
Optical Sensor 1 Input Not Active During Powered Gate Movement
B2706
Optical Sensor 2 Input Not Active During Powered Gate Movement
B2709
Gate Open Output Short To Battery
B2710
Gate Close Output Short To Battery
B2711
Gate Open Output Short To Ground Or Open
B2712
Gate Close Output Short To Ground Or Open
B2713
Unlatch Output Short To Ground Or Open
B2714
Uncinch Output Short To Ground Or Open
B2715
Cinch Output Short To Ground Or Open
B2718
Gate Ajar Output Short To Battery
B2721
Gate Ajar Output Short To Ground Or Open
B2722
Open/Close Switch Active During Self-Test
B2723
Glass Position Switch Active During Self-Test
B2724
Forkbolt Switch Invalid During Self-Test
B2725
Detent Switch Invalid During Self-Test
B2726
Home Switch Invalid During Self-Test
B2819
Gate Motor Circuit Short To Battery
B2820
Gate Motor Circuit Short To Ground Or Open
B2821
Cincher Motor/Unlatch Actuator Short To Ground Or Open
B2822
Cincher Motor/Unlatch Actuator Short To Battery
B2825
Movement Ceased Due To Excess Speed Deviation
B2903
Chime Output Circuit Short To Battery
Power Liftgate Module/ Liftgate Chime Module
GO to Pinpoint Test C.
C1935
Chime Circuit Failure
U1950
UBP Communication BUS Fault
UBP Communi cation
REFER to Section 418-00.
U2338
Invalid ACM Message Data
Feb 05, 2015 | Lincoln Cars & Trucks
Feb 02, 2015 | Nice Robuskit Slide Gate Operator Motor...
Jan 16, 2015 | Lincoln Cars & Trucks
Aug 20, 2014 | Cars & Trucks
Jul 29, 2017 | Garden
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Apr 06, 2009 | Eidos Interactive Lara Croft Tomb Raider:...
Jan 08, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Apr 23, 2017 | Home Fencing
522 people viewed this question
