SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
SOURCE: Sunbeam mixmaster jammed, will not
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
SOURCE: Sunbeam Heritage Mixmaster Won't Tilt
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
SOURCE: My sunbeam mixmaster blades wont turn but the
Hi, GLENNHOLD148 - With a motor that runs and the blades do not turn, it appears that your mixer's suffered a mechanical failure in the mixers transmission. I don't know if your mixer is under warranty, but I suspect like any small appliance the warranty's only good for a year, and you've probably had it much longer than that. That leaves with with three options; purchase a replacement (Sunbeam and the economy would appreciate that!), take it to a local authorized Sunbeam repair shop, and finally attempt to repair the transmission yourself (DITY repair). The later can be most gratifying, however, sadly, Sunbeam doesn't provide Parts List manuals like some other mixer brands, e.g.; Kitchenaid, so I can only suggest Option 1 or 2. I wish I could offer you more help. Hopefully this will help point you in the right direction. Howard - Burke, VA
If this solution has helped, please rate it, thanks! - hslincoln
SOURCE: New mixer did not come with manual
Hi MITCH, Happy New Year! Somebody at Sunbeam must have been asleep when the mixer passed by on the production line...duh? I hate when that happens. The good news is that you can download a PDF Users Manual from the Sunbeam website. Just click on this link Heritage Series 2353 Mixmaster and look for your M-I-L’s model to about ½-way down the page. Open the file and save it to your PC.
I’m not very keen with the way Sunbeam lays out their User’s Manuals. You’ll need to do some editing and repaginating to get it into a format that your M-I-L- can use, but at least you’ll have it. You can send it to her electronically or print just the English pages and mail; your choice.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
