Question about Samsung Televison & Video
Hy i have samsung ue40d5003bw and half of display (up) is horisontal lines with picture and half of the diplay (down) is clear picture.
Willing to send a picture of problem if there is any chance to repair it.
Posted by Dario Somodi on
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
Samsung uses a power board with one capacitor. (Ignore the video and input boards.) Check high voltage across the capacitor - should be 390 to 400 volts DC. If not the capacitor needs to be changed. Samsung uses 100 uf rated at 450 volts. I replaced it with 370 uf rated at 400 volts. (Did not have a 450 volts lying around.)
Posted on Nov 25, 2017
Testimonial: "TCON card is broken"
5 Related Answers
Anonymous
  • 208 Answers
SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
Posted on Feb 03, 2008
Mergatroid
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
Anonymous
SOURCE: How to fix horisontal lines on display ( see the picture)?
I would like for you to tell me why my email message is on the right side of the screen with blue lines a white and yellow on the left. I do not have horizontal arror bar at the bottom to adjust the screen.
Posted on Feb 15, 2008
Anonymous
  • 7 Answers
SOURCE: black ink does not print full words, misses bottom
maybe the jets are a little blocked up?
Posted on Oct 15, 2009
Anonymous
  • 1099 Answers
SOURCE: I have a 5 yr old Samsung HP-R5012 Plasma Display
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 11, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Tv turns on ok,first displays black screen with 2 horisontal lines and some static at the top,than slowly from the top down i can see picture,after 5 min i can wacht tv but i have 2 lines -horisontal and...
Hi Marcin,
First of all, thank you for posting your question here at Fixya.
To diagnose accurately the exact caused of the symptoms, please let me know the Brand and model/chassis number of your unit. It is printed at the rear panel, manual and on the receipt. It will help to narrow down the symptoms and locate the availability of parts online.
Jdvillanueva
Jan 20, 2012 | Televison & Video
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Horisontal lines
Same's happened with my Pentax WR, and a mate's Optio...
You're not alone, and we don't know why - we're gonna send them back to Pentax.
Jun 05, 2008 | Pentax Optio M10 Digital Camera
Error code 000002 on cannon image runner
You have to get into service mode and clear the code. First, press the aditional funcation botton on the control pannel then the numbers 2 & 8 at the same time then press the aditional funcation key again. The diplay should change. Press the copier box and the at the top in the middle of the display " Funcation" the display changes again, then in the 2nd colum about half way down you will see "Clr" touch that box and then at the bottom right of the display touch the " OK" box then turn the main power switch off then back on and that should solve the problem. You may have a bad power problem with the wall outlet if it is not the right voltage, it will play havice with the copier. Good Luck
Mar 31, 2008 | Office Equipment & Supplies
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung projection tv
Unplug it and plug it in again. This worked for me and I have a very similar problem occasionally. Turning the power off and on with the remote will not work.
Oct 20, 2007 | Samsung SP42P2S Television
Televison & Video Logo
Demonic-2011
Demonic-2011
