Question about Honda Electrical Supplies
Honda ex5500 generator over voltage output
Generator is deleviring over 175 volts output
Posted by Tany Ramos on
Bill Boyd
    Top Expert:
  • Honda Master
  • 53,816 Answers
Adjust the rpm back to 115-120 volts
or increase voltage to 220-245 volts
Posted on Nov 25, 2017
Testimonial: "Hi, rpm and hz correct, AVR replaced and continued with over voltage, Diode stack working properly, 300 ohms rheostat burned and replaced with new one and also burned. During troubleshooting damaged Diode stack and ordered a new one and waiting for it. Thanks for your help."
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: portable generator low voltage
85 volts represents residual voltage. It is possible that your unit sat for an extended period and lost it's magnetism or the excitation system failed under load. check your manual for a procedure to "flash the field". If that is not successful, e-mail me and I'll tell you how to trouble shoot the failure.
Posted on Jan 04, 2009
Anonymous
  • 10 Answers
SOURCE: voltage output is only 50 volts instead of 120 volts
More than likely your voltage regulator is out. The generator produces electricity, so you know the rotor and stator are OK. The 50 volts comes from the magnets permanent properties. The reason you are not getting 120 is because rotor or electron magnet is not getting any power supplied to it, which it needs to produce the amount of electrons you need to have 120vac. Make sure your engine is running at 60 hz first, and you should ohm out the windings and circuits that connect to your regulator.
Posted on Feb 05, 2009
CarlGehrke
Carl Gehrke
  • 169 Answers
SOURCE: low voltage generator output
Nothing about the bumpy dirt road would have done this but the 10 years of storage might mean that you've got dirty slip rings. Plugging a drill into the 10Kw generator isn't going to tell one much about the power coming out of it, you need a stove :-)
After a camshaft replacement I'd want to use the "Hz" function of the DVM to make sure I was getting 60 Hz.
Regards,
Carl
Posted on Feb 23, 2009
Phil Rivera
  • 83 Answers
SOURCE: Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
Posted on Mar 31, 2009
97F350diesel
James Brooks
  • 1326 Answers
SOURCE: I have a Honda EB5000 Generator with no a/c output
Is this run on a xfer switch, have items just plugged into the generator or just run into an outlet. If on a xfer switch if not it could back fed electricity to the generator and fried it.
Posted on Aug 21, 2009
What is causing the battery to drain?
Running the car will drain the battery it if it's not charging ! An if your charging light is on it isn't charging ! Did you check power an grounds on the alternator ? There is a single heavier wire on the back of the alternator, this should have battery voltage ! You may want to take this to a ASE certified repair shop !
Functionality
With the ignition switch in the RUN position, voltage is applied through the warning indicator I circuit 904 (LG/RD) to the voltage regulator. This turns the regulator on, allowing current to flow from battery sense A circuit 35 (OG/LB) to the generator field coil. When the engine is started, the generator begins to generate alternating current (AC) which is internally converted to direct current (DC). This current is then supplied to the vehicle's electrical system through the output (B+) terminal of the generator.
Once the generator begins generating current, a voltage signal is taken from the generator stator and fed back to the regulator S circuit 4 (WH/BK). This voltage feedback signal (typically half the battery voltage) is used to turn off the warning indicator.
With the system functioning normally, the generator output current is determined by the voltage of the A circuit 35 (OG/LB). The A circuit 35 (OG/LB) voltage is compared to a set voltage internal to the regulator, and the regulator controls the generator field current to maintain the correct generator output.
The set voltage will vary with temperature and is typically higher in cold temperatures and lower in warm temperatures. This allows for better battery recharge in the winter and reduces the chance of overcharging in the summer.
Battery Positive Output (B+) Circuit 38 (BK/OG)
The generator output is supplied through the battery positive output (B+) terminal on the back of the generator to the battery and electrical system.
I Circuit 904 (LG/RD)
The I (ignition) circuit 904 (LG/RD) is used to turn on the voltage regulator. This circuit is powered up with the ignition switch in the RUN position. This circuit is also used to turn the charging system warning indicator on if there is a fault in the charging system operation.
A Circuit 35 (OG/LB)
The A (battery sense) circuit 35 (OG/LB) is used to sense battery voltage. This voltage is used by the regulator to determine generator output. This circuit is used to supply current to the generator field (rotor). The amount of current supplied to the rotor will determine generator output.
S Circuit 4 (WH/BK)
The S (stator) circuit 4 (WH/BK) is used to feed back a voltage signal from the generator to the regulator. This voltage is used by the regulator to turn off the charging system warning indicator. The S circuit is fed back externally on external mounted regulator generators.
Visual Inspection Chart Mechanical Electrical
  • Battery case, posts, hold-down clamp, cables and connections
  • Generator drive (serpentine) belt for condition and tension to make sure there is no slip between the belt and the pulley. For additional information, refer to Section 303-05 .
  • Battery charge
  • Generator pulley
  • Battery junction box (BJB)Mega Fuse
  • Battery junction box fuse:
    • 11 (20A)
  • Central junction box (CJB) fuse:
    • 30 (30A)
  • Circuitry
  • Charging system warning indicator
  • Cables
  1. Check the operation of the charging system warning indicator lamp (instrument cluster). Normal operation is as follows:
    • With the ignition switch OFF, the charging system warning indicator should be OFF.
    • With the ignition switch in RUN and the engine off, the charging system warning indicator light should be on.
    • With the engine running, the charging system warning indicator light should be off.
  1. Verify the battery condition. Refer to Section 414-01 .
Normal Charging System Voltages and Charging System Warning Indicator Operation Ignition Switch Position A Circuit 35 (OG/LB) S Circuit 4 (WH/BK) I Circuit 904 (LG/RD) Generator B+ Circuit 38 (BK/OG) Battery Engine to Battery Ground Charging System Warning Indicator Operation OFF 12 volts 0 volts 0 volts 12 volts 12 volts 0 volts Off RUN-engine off 12 volts 0 volts 1-3 volts 12 volts 12 volts 0 volts Illuminated RUN-engine running 13-
15 volts 1/2 battery voltage 13-
15 volts 13-
15 volts 13-
15 volts 0 volts Off
  1. If the customer concern is verified after the initial inspection, refer to the Symptom Chart to determine which tests to carry out.
    • The charging system warning indicator is on with the engine running (the system voltage does not increase)
    • Circuitry.
    • Voltage regulator.
    • Generator.
    • GO to Pinpoint Test B .
    Your whole problem is the alternator is not charging , a couple tests with a volt meter would tell you !
Aug 16, 2015 | 2001 Ford Expedition
Have continually to increase speed to maintain voltage
Check the idle-stop screw. They tend to back out, causing the generator to slow down and not maintain regulation
Oct 17, 2014 | Honda Ex5500 Generator Solenoid Stay...
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
Dec 05, 2013 | Northstar North Star Honda 13hp 8000 Ppg...
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Back up generator 240 volt output is off balance?
So there is a problem. Where are you measuring voltage?
Say there is L1 - N - L2. Line1 to Neutral is 120 volts, Line2 to Neutral is also 120 volts, Line1 to Line2 is 240 volts. N or Neutral ( the grounded conductor ) is center tap between line 1 and 2.
With this system, the N wire carries the unbalanced load in amperes .
Now we are talking of L1 and L2 and amperes. When L1 and L2 are conducting 10 amperes each, N carries 0 amperes, Line1 and L2 are balanced. When L1 carries 10 amperes and L2 carries 5 amperes, Line1 N carries 5 amperes, the difference of L1 and L2. This is normal.
When there is a problem with a loose connection on N, there is a resistance and will not carry the unbalanced load normally, the voltages will Chang's under load, the problem will worsen with time, a fire hazard, connected loads may burn up from excessive voltage or not work at all.
Bottom line: Make sure the N line ( white wire ) is tight at every connection and inspect for overheating damage. You may have to open the generator connections panel to check there too.
Aug 06, 2017 | Electrical Supplies
Output is only 99 to 100 volt. Unit works fine
hmm.... try running it for a while with something plugged in that won't mind the voltage drop... like a light bulb..
Dec 05, 2009 | Honda 3000 Watt Portable Generator
5250 running watts output on 220 side is 300 volts, 120 side is 175 volts what is wrong
I can't tell you what type of rotor excitation you have without the model number but,
If its capacitor excited then you have a bad capacitor(s). If it has a voltage regulator then it could be bad or the sensing wires going to it are bad. If the unit is not sensing proper voltage its going to increase excitation thus causing your units voltage to be to high.
Nov 29, 2009 | Coleman Powermate Premium Plus 6250W...
Voltage output is only 50 volts instead of 120 volts
If you need troubleshooting help for your Honda or other portable generator there's nothing better than a handy schematic. This detailed diagram will help you troubleshoot your portable generator. In publications or online you may find a variety of schematics for Honda or other portable generators.
One handy book, which can be ordered online and delivered straight to your home offers troubleshooting guidance, including a number of schematics, for Honda, ATI, Coleman, Generic, John Deere, Mitsubishi, North Star, Porter Cable and Robin Subaru portable generators.
The book, entitled, Small AC Generator Repair and Service Manual - 1st Edition Volume 2, is discounted for under $30 on one Web site.
This portable generator troubleshooting publication is 420 pages, replete with schematics in the former of illustrations and diagrams.
Jan 25, 2009 | Honda 3000 Watt Portable Generator
Electrical Supplies Logo
656 people viewed this question
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
